Anyone used a Soundcraft Compact Stagebox with a Yamaha board, using any combination of ethersound or dante cards on either devices?
thks
thks
thks
The stage box I am talking about is the one that has option cards and there is an ethersound card option for tha stage box
thks
What is the part number for that card? Searching the soundcraft pricing sheet (I am a dealer) "ethersound" is not present at all. Next to all of the expansions cards that they do offer it says "For use in Si Console Expansion Slot Only". Needless to say, I don't know why anyone would try this based on the lack of head amp control. It would be a deal breaker for me.
the card is not shown in soundcraft lists because is available thru Digigram,( http://www.soundcraft.com/products/vi-option-cards );
it is a VI card compatible with the COMPACT STAGEBOX, the card I have on the STAGEBOX is the cat5 Madi with 422 , so maybe the head amp controlling could be done thru it. My case is that I have several Yamaha boards and I am looking for the option to use the Soindcraft Stage box , if the ethersound of the yamaha protocol would not talk to the stagebox even with the ethersound option card on it I could swith to a Yamaha Madi card (bnc option) and use a madi coax to madi cat5 converter, what do you think?
DF
DF
I think you'll end up with another 2-3ms of latency, maybe more. And that's IF you can get it to work at all. Neither kludge addresses the head amp control issue.
Why do you insist on using the Soundcraft stage boxes?
so getting option card for either end ( board or stagebox) would be cheapier than getting another SB
[/LIST]
I would agree that the CL/QL implementation is better, but why would you say that the previous consoles are "not really suitable"?Yamaha consoles prior to the CL and QL series are not really suitable for digital snakes as we know them today.
Dear can you explain what exactly will happen when connecting sdcraft mini with Yamaha tf1 with my 64 card plsRe: Soundcraft Stage boxes with Yamaha boards
As I've said many times before, "the wrong piece of gear at the right price is still the wrong piece of gear". Your plan is great, except for the part about it not working.
Having a stagebox that will pass audio but have no control is a step back from running an analog snake. This is a lot of figuring out for not very many channels.
Mac
