I posted this over in the Yamaha Digital Group, but Yamaha released the StageMix application software for the LS9 today...
http://itunes.apple.com/app/ls9-stagemix/id406087165?mt=8
EQ your headset microphones on a corporate gig ON the stage without having to drag a laptop around. wonderfull. I'll also be able to go next to the musos on stage when we're soundchecking next time (i'm touring a lot with ls9 on monitors) and this will be even if only psychological be a big advantage. loving it, absolutely loving it.
Hey,
Used it in anger the other night. They have a nice ipad follow desk cue so your eq changes as you click through your channels letting you use the ipad to eq things insted of the rotorys...... Amazing. Halved my fustration with the desk. Made the night easy. Eqed wedges from stage. Happy Kim.
LS9, next gerneration with an iPad taped to it ;-)
Yeah, John, I totally agree with you. Since I was doing a hour set each day of a two day festival I decided to take my console and leave it on the deck. The show is completely dialed in from months of touring so I only push faders at this point anyways. The reason I ask is because this being my first outing with it as well. I'm prodding around because every time the meters seems to hang up I got that nervous feeling that I might be about to lose connection. I eventually just got comfortable with the glitch since it didn't last for more than half a second.
I did lose a connection twice: Once during my sound check because I made the mistake of trying to run the Remote App at the same time forgetting that the air card is shared between the WAN and Bluetooth. Secondly, at the beginning of the first night I lost a connection for some unknown reason and had to walk up to the console and get close to the LS9 to reconnect.
One thing you might try is turning off the meters. They take 99% of the bandwidth, control only takes 1%.
Steve- if you are going to do this with your band then your FOH guy can use the LS9 and you use the iPad simultaneously. You will just want to use the other layer so you can have independent EQ. You will have to share the head amps.
