Re: "Tectonic plates" from the front page.
UNTIL it is struck. And just look at the striker. How many bells have you seen that have multiple strikers? None that I have seen. The ones I am aware of use a SINGLE striker-just like a single loudspeaker driver.
So how do you describe "volume". Most people think of it as Sound PRESSURE Level.
Any clean system will not sound loud until you try to talk. It happens all the time.
I'm sorry but I don't get the whole "Direct sound is canceled by reflections back into it".
Yes I will agree that SOME freq could be reduced. But that is the nature of combfiltering within the whole room due to different arrival times from loudspeakers and reflections (or multiple loudspeakers covering the same are), peaks and dips in the response.
But since the phase of different freq has different wavelengths-at a given distance from loudspeaker to reflective surface, at some freq the "returning wave" will be out of phase (causing cancellations) and OTHER freq will be in phase-CAUSING ADDITION in level. Other freq will be somewhere inbetween.
I'm sorry-but I need a better explanation to "understand" what is going on. I have just never heard of somebody trying to reduce feedback by adding more reflections. Maybe that is a new approach
A bell has NO polar pattern and makes NO sound!!!!!!!!!!!!!!!!!!!!Thanks
It is like a bell. This panel is just vibrating in air like a bell, but it is flat.
One reason I was thinking it did not feedback standing in front of it is that like my home Acoustats, if you add lots of surface you get lots of volume, but not the pressure or ( " Throw" har har ) like a horn. I can drive you right out of my listening room with level but you do not go because it doesn't drill you. You do not even realize how loud it is until you try to talk to someone else in the room.
That lower velocity is also met by cancelation from all other points on the panel, again a laymen understanding but, The direct sound form the closest point to a mic is canceled by a point slightly longer and longer and longer.
I have to play with one just to find out. A true wall of sound, it is off to the shop.
