How wide is your truck pack? If its not one of the usual suspects, please pick "other" and leave a message in the thread with the actual width.
Thanks!
Thanks!
My company box truck is something like 88" which is a pain, but I've mastered packing it.
The 16' gas, and NPR trucks around here tend to be 90"
The 24' and 26' trucks are usually 96"
I've started building my cases to pack both ways; 24x22.5, 30x24, etc. that way you just rotate them to fit whatever truck.
Yep. And cargo vans (and Sprinters, and their ilk) tend to be narrower still, but have enough other obstacles that you're playing Tetris no matter the case size. 24x30 seems to be a popular size that fits both trucks.
Phil,How wide is your truck pack?
Phil,
I have been building cabinets to 90" truck integers since 1979, (almost) all the rental trucks back then were at least 90" clear between ribs. I recently sold my van and trailer, so for the last show I had to rent a truck for the first time in 20 years, the 16' Budget truck was a 90"+ (91" between side boards actual) width, same as ever. The Santa Fe local trucks and other interstate Budget rentals on the lot were all the same width.
Are the usual "Rock Box" (Electronics Van) trailers as rented for most big USA tours from companies like Upstaging now 102" interior width?
Art
Sorry to dig up an old thread, but I'm wondering where you measure your road cases for these dimensions. At the ball corners? At the aluminum corner extrusions? And do you undersize your boxes by 1/4", or do you go with exact dimensions? Thanks in advance!
Grant
