Is there a way of measuring/verifying tuning frequency for a vented enclosure?
And what kind of air velocity do you consider "too much" when designing a port?
It seems like there are multiple terms involved. You might be able to empirically determine that vent tuning is peak for the driver/box combination, but I don't know how to easily isolate the port for measurement.Is there a way of measuring/verifying tuning frequency for a vented enclosure?
I am not a speaker guy but when turbulence from air flow becomes audible, could be a problem.And what kind of air velocity do you consider "too much" when designing a port?
I said I wasn't a speaker guy, but back in the '80s I designed a piece of cheap test equipment that allowed simple impedance sweeps. Basically drive the speaker cabinet with a signal sweep through a fixed resistance, and measure the voltage drop across the resistor. This signal doesn't need to be very loud, just enough to get a clean voltage drop measurement (1v or so works),Impedance sweep, or by looking at the cone excursion minima. The former is more informative if you have the tools, the latter can be done for free.
Is this what they mean when they say the port is being "choked"?For the air velocity, the port will start undergoing substantial compression at a Reynolds number between 50,000 and 100,000. These effects are dependent on the port geometry. The reynolds number can be calculate for the port geometry, but for common geometries a reynolds number of 50K corresponds to approximately 7 m/s. Usually port velocities up to 15 m/s can be had without too much port noise, but of course there will be port compression happening.
I'm looking at a design using a high excursion 18" driver in a cabinet with a large port for a tuning around 28.5Hz.
The cabinet is simulated in WinISD, and it looks like "everybody" on the internet agrees that you'll have to verify your port tuning with a prototype build because WinISD gives you a port length that is too long.
So, using this approach, I was thinking about constructing a prototype,measure the actual tuning and adjust the port length if/as needed.
With the search function, I noticed that several people on this forum have recommended Dayton Audios woofer tester for doing impedance sweeps. It's affordable, but is it reliable?
http://www.parts-express.com/dayton-audio-dats-v2-audio-test-system--390-806
Excuse me, my highly technically affluent comrades, but why does the port tuning shift as volume increases?
A whole bunch of fluid dynamics that I erased from my brain immediately after getting my college diploma
http://www.fohonline.com/home/20-features/6031-tech-feature-subwoofer-ports.html
