...I touch the black wire?
Didn't your mamma tell you not to touch things that you do not know what they are?
Of course that is how we learn.
Touching the black wire is not as bad as using your teeth as a wire stripper and finding out the circuit is live.![]()
Had an old friend who did that, the AC didn't hurt him (much..), but just found out alcohol eventually killed him.
Do pro level wires come in a color other than black? Or are you talking about the connector? I guess then it would depend on what the other end is connected to.
I now carry a non-contact tester
If I had a dollar for every time one of those lied to me....
Long ago in my padawan days I got shocked by touching the white wire.
I was troubleshooting a problem in my house (wire slipped out of a wire nut), and some device was plugged into the circuit in question. The loose wire was on the return path (white), so I assumed I was OK to work on the circuit live (stupid ASSumption), and when I was sticking the wire back in the nut, I completed the circuit with my fingers.
That was the last time I assumed anything about electricity.
I now carry a non-contact tester, VOM, and occasionally 1K par can to any questionable electrical situation.
Somewhat less than if you touch the brown, yellow, or orange wires.
Quote: said:A delta-wye (Δ-Y) transformer is a transformer that converts three-phase electric power without a neutral wire into 3-phase power with a neutral wire. It can be a single three-phase transformer, or built from three independent single-phase units. The term Delta-Wye transformer is used in North America, and Delta-Star system in Europe.
Delta Wye Transformer
Delta-wye transformers are common in commercial, industrial, and high-density residential locations, to supply three three-phase distribution systems.
An example would be a distribution transformer with a delta primary, running on three 11kV phases with no neutral or earth required, and a star (or wye) secondary providing a 3-phase supply at 400 V, with the domestic voltage of 230 available between each phase and an earthed neutral point.
