What sort of rig are you running?
Re: What sort of rig are you running?
My club rig:
2-JBL VP7215/95DPAN tops, on stands, machined my own pole sockets
4-JBL VPSB7118DPAN subs
DSP-System Architect through a wireless router
2-dbx 1046
1-dbx 1074
1-Lexicon MX400, 2 stereo verbs
Mixers-Mix Wiz or GB4-24
Monitors from FOH
Wedges-6 JBL VP7212MDP
2-Ashly Protea 4.24 EQ's
What! No amp racks?
All ProCo Sound snakes and cables
All Sennheiser E900 series mics
My FOH rig becomes the monitor rig when I do large shows with a friend. I use the same outboard rack, one VP top and VP sub for drumer. I have a couple PRX512M's I use for small FOH or extra wedges in a pinch.
Monitor console-A&H GL2800M-840
4-Sennheiser G3 IEM's, 4 stereo mixes w/stereo verb
6-Wedges, the same JBL VP7212MDP
Transportation-Chevy 1500 with camper shell. Yep, it all fits. On smaller shows, barely. Sometimes I'll rent a 5X8 U-Haul for the larger gigs. Only $20.
I provide for bars and clubs locally, with a few larger outdoor shows, but mainly a barfly in the 200-300 person size rooms. Everything goes in a 12x7 Homesteader Lowrider trailer with rear ramp. Generally use IEM for everyone so monitors are not an important part of my system, but I have some old school boxes.
4 QRX212
4 LS1208
XTI4000 for tops and monitors (4)
XTI6000 for subs
ITech 6000 for subs
01v96 V2
Presonus D8 (2)
EWI 32/8/150
ATW3000 series wireless (4) (Each has a dynamic mic and a beltpack available)
AT M3 IEMs (4) with 5 receivers
Sennheiser AC2 antenna combiner
ATW DA49 Antenna distributor
Senneheiser 1031 paddles for everything
SR4706a monitors (2)
EV FM1202ER (4)
Mics are the usual suspects of Audix D series (2 D6, 2 D4, 4 D2, 2 D1), Audix OM series (2s, 5s and 6s,) Shure SM86 (3,) B-87 (2,) SM57 (10,) SM81 (3,) and the obligatory Crown CM311 headsets (4) and Countryman E6 (1.)
Radial J48
Radial ProDI
Radial ProD2
12 K&M stands with booms.
iBook G4 with Spectrafoo and RFGuru
HP DV6000 with iTunes and Bluelite
Off topics:
ADJ LED par cans (12x 64's 2x56's, 8x38's, 2x Megabars)
2 ADJ Galaxian Sky lasers
1 Martin Minimac Maestro
4 Martin MX4 scanners
Radiance Hazer
Global Truss ST90 stands (6)
Global Truss F34 Box Truss (3x5' and 2x10')
Bluelite X1 Software
DMXIS Software
Martin Freekie
Copy and paste from my web page:
Mains
• 4 Rat Sound Rat Trap 5 4-Way Quad Amplified Full Range Top Boxes (EV 15''x2, EV 10''x2, JBL 2'', TAD 1'')
• 4 Rat Sound Subwoofers - Double 18'' (EV EVX-180B Loaded)
• Crest Audio Professional Series 8001, 7001, 4801 Amplifiers
• Xilica DLP4080A 4-Way Stereo Processor/DSP for Tops
• BSS FCS-966 EQ for Top Box EQ
• BSS FDS-310 Crossover with Symetrix 501 Limiter for Subs on Aux Send
• Ashley PQX-571 Parametric EQ for Subs on Aux Send
Monitors - Up to 8 Mixes from FOH or separate monitor desk (A&H GL2200-32)*
• 4 Mackie SRM450 Wedges (Self Powered Bi-Amped 12'' 2-Way)
• 4 Mackie SR1530 Side and Drum Fills (Self Powered Tri-Amped 15'' 3-Way)
• 2 Turbosound 18'' Subwoofers for Side Fills
• TDX CX Series Crossovers for Side Fill Subwoofer/Tops Split
• Crest Audio Professional Series 7001 Amps for Side Fill Subs
• DBX 2231 1/3rd Octave EQ's for Monitor Mixes
Mix Desk - FOH
• Allen & Heath GL4000 48 Channel, 8 Group, 10 Aux Mix Desk
Dynamics & Effects
•DBX 1046 4 Channel Compressors
•DBX 166XL 2 Channel Compressor/Gate/Limiters
•DBX 266XL 2 Channel Compressor/Gates
• FMR RNC 1773 Stereo Compressors
• UREI/JBL 7110 Compressor
• Aphex 622 2 Channel Noise Gates
• Aphex 612 2 Channel Noise Gates
• TC Electronics M-One XL Digital Reverb/Multi-Effects Processors
• TC Electronics D-Two Digital Delays
• Lexicon MPX-500 Multi-Effects Processor
• Lexicon MPX-1 Multi-Effects Processor
• dbx 120A Sub-harmonic Bass Synthesizer
Mics & DI
• Audix D, ADX, & i5 Series Instrument Mics
• Audix OM Series Vocal Mics
• Shure SM & Beta Series Vocal & Instrument Mics
• Sennheiser Evolution 100 Series Wireless Mics
• Countryman E6 Ear/Headset Mics
• Whirlwind Hot Box Active DI's
• Whirlwind Director Passive DI's
• Whirlwind pcDI Stereo Active DI's
• Whirlwind IMP2 Passive DI's
Snakes & Stands
•Whirlwind Medusa 24 x 8 ch. Snake w/ Monitor Split*
•Pro Co 24x8 ch. supplemental snake when more than 24 inputs are required
•Whirlwind Medusa 12 ch. Return Snake
•Whirlwind Mini 6 & Mini 12 Sub-Snakes
•K&M Boom Mic Stands
•Atlas Straight Mic Stands
Mix Desk - Monitors*
• Allen & Heath GL2200 32 Channel, 6 Mix + Stereo Side-Fills (8 Mixes Total)
Extras
•Tascam CD Recorder
• Mackie MDR2496 24 Track HD recorder
• SMAART 7 Mac FFT Analyzer
• Audio Control RTA
Our small all purpose system is used for my wife's all female 4 piece rock and blues band in small venues and for private gigs. In our area all the larger venues and festival gigs have PA provided. It was put together in the hope of fitting the PA and all band gear into A 5x10 Wells Cargo trailer but alas some gear still must ride in a separate vehicle due to the trailers weight rating.
Mains: 2x Community S3294 12''x6.5''x1''.
Subs: 2x Danley TH Mini 12'' tapped horn.
Monitors: 3x DIY Assistance Audio 12''x1'' coaxial.
FOH: Mix Wiz 16:2
DBX DRPA
DBX 2231
DBX 1046
Peavey Q231FX
TC-M Onexl
Audiopile 16x4 100' snake
200+lbs of various cables.
Mic case:
2x SM58
3X SM57
1x Beta 87A
1x AT AE3300
AT AE4100
2X Sennheiser 609
1x Sennheiser 906
1x Audix D6
1x Sennheiser 604
2x Rat Shack 604 knock offs
2x Octavia MK-012-01
Amp rack:
1x QSC PLX3102
1x QSC PLX1602
1X Carvin DCM1204
All in all a pretty nice relatively light weight system for up to about 200 people at our levels.
Winston
Hello all!
My rig currently:
Mains - 2 x JBL4732-x
Subs - 2 x JBL4719-x
Amps - Crown XTi6000 subs, XTi4000 mids & XTi2000 his
Im using the DSP in the XTi amps
FOH console - A&H GL2400-32
FOH rack - Yamaha REV500, Lexicon MX300, Lexicon MX200, 3 x DBX 266XL and a TC C300
Monitor console - A&H Mixwiz V3 16:2
Monitor rack - 3 x DBX 231, 2 x Be*%#$er MDX4600, 4 x EWI MST412
Wedges - 4 x JBL PRX612M, 2 x JBL PRX615M
Snakes - Whirlwind 24 x 8 x 100, several EWI box and fantail snakes for stage and drive runs.
Mics - Sennheiser 604s, 609s, 421 and e945, Shure b56, b58, sm57s, sm58s AKG D112, Audix f10s, f12, f15s and Altec a42.
Power - home made single phase distro, 5 x 20amp breakers / duplex outlets and 125' of 6/4 feeder.
My Brother made all my cable and stand trunks and they kick ass.
Plenty of stands, mic cables, power cables, yadda, yadda, yadda
It all goes in a Pace 6x12 trailer that I haul behind a 2002 4Runner.
Ive been working on getting monitorworld up to snuff recently and am finally real happy with it so its time to look at other upgrades. I know at some point Ill need a 150' snake possibly 32 channels. The mains are another area that Id like to upgrade. The SR-x stuff sounds fantastic but its a bit heavy...
<u>Mixers</u>
A&H GL2200-24 in Anvil case
A&H GL2400-16 came with Grundorf case
Yamaha MG166 no case
<u>FOH loudspeakers</u>
SPL Trik Traps x2
SPL Runts x2
15 x 1 Neo Traps-B&C 15'' Neo, B&C DE-45 1'' hf, DDS horn. x2
<u>Subs</u>
JTR Orbit Shifters x2
Servodrive Contrabass x2
<u>
Monitors</u>
BMS Coax Wedge x4
Emminence Coax Wedge x4
Peavy BW 1203 x JBL 2426 1'' on DDS horn x2
<u>Amps</u>
QSC PLX 3602 x3
Yorkville A4.4
QSC PLX1804
Crown MT600
Crown Comtech 200
<u>Processing</u>
Ashly Protea 4.24c
Audient One 2x6
Amps and processing housed in R&R deep rack cases
<u>Graphic EQs, FX, other outboard</u>
White 4660 x4
White 4650 x4
Rane GE27 x2
Yamaha SPX90
Marantz CD player
Housed in a couple of L&M 18'' deep rack cases
<u>Mics, DI's, etc.</u>
Shure SM86 x5
Crown CM-700 x4
EV n/d308
EV n/d468 x2
EV n/d868
AKG D112
Shure SM58 x2
Audix OM7 x2
ATM 35 x4
Senn 504
Crown CM200
3-4 Strays
Countryman DI x4
Whirlwind Director DI x4
Whirlwind Medusa 24x6x100 snake
Ultimate speaker stands
K&M mic stands, 10 tall boom, 4 low boom.
AKG headphones
<u>Cable</u>
Gepco mic cables app. 1200' total, half Xband, half 1022
12/3 SEOOW AC cable. app. 400' all Hubbells
14/4 SJ speaker cables, app. 500'
EWI 24 ch. split snake
Looking at finally getting some decent comps and gates. Have an Aphex 106 4ch comp in the FOH rack.
Best regards,
John
My stuff resembles Matt's in many ways so I stole his format
I have ''2'' FOH Rigs.
My ''A-rig'' consist of:
Mains: 2 pair of EV QRx212
Subs: 4 JTR Growlers
FOH Processing: Sabine NAV480
FOH Amps: QSC PLX1602 and PLX3402 on mains, QSC PL6.0 on subs
Monitors: Wizard Sound 12'' B&C Coax loaded wedges
Mon Amps: QSC PLX3402 x 2
My ''B-rig'' consist of:
Mains: QSC K12s
Subs: QC KW181s
FOH Amps: none - powered speakers
Monitors: Wizard Sound 12'' B&C Coax loaded wedges (same wedges as the A rig)
Mon Amps: QSC PLX1804 x 2
My Mixers: I have an Yamaha LS9-32 and a 01V96. I tend to use the LS9 as my primary mixer. I have a pair of OctoPre preamps to add inputs when needed.
Snakes and Mic Cables: I tend to use products from EWI, I have their 24x8x150 on a reel. I have several sub snakes to keep the stage clean. I use almost all Starline cables.
For transportation I own a 2005 Dodge Ram1500 with the Hemi pulling a 7x12 tandem axle trailer for the ''A'' rig and a Dodge Grand Caravan for the ''B'' rig.
Room for improvements:
I could use another pair of powered speakers so am looking at getting a pair of QSC KW122s when I can afford it.
I would like some lighter weight wedges for the ''B'' rig that can also be used with the ''A'' rig when needed. Something like the MRX512M or the SRX712 would do. Microwedges would be real nice.
I also would like a 15'' speaker for the drummer wedge.
In the future, I would like to to sell my 01v96 for an LS9-16 for the consistency of the user interface.
Edit: fix typo
Here is a ,list of what I have. Depending on the event I mix and match as needed. My main gigs are in the Portuguese market, DJ'ing and running sound for bands and ''playback'' artists.
2- Jbl Srx 725s
2- Jbl Srx 728s
6- Jbl Srx 712m
1- Amp rack with rac pac, 2-IT8000s, 2-Xti 4000, I/O panel.
1- 6U rack with another 2-XTI4000s
1- Allen & Heath GL2200 24ch mixer
1- Yamaha 16ch mixer
1-Pro Power 3 phase distro with edison and L14-30
Lots of Digiflex mic, 1/4'', and NL4 speakon
Various lengths of feeder cable
FOH
2-Tascam CD-UO1 pro cd players
2- Ashley GQ3102
1- Ashley compressor
1- Furman power conditioner
1- Yamaha Rev500 effects
24x8x200' snake with power loomed to it (the 8 returns are xlr or 1/4'' on the snake head)
Various sub-snakes
Lighting
2-Mac 250 entours (buying two more next month)
6- Martin SCX600s
20- Led par cans (bars of 4)
1- LeMaitre G150 smoke machine (hoping for a Radiance hazer soon)
12- Par64s (old school)
1- Lightjockey
Acouple dimmer packs
Sure I'm missing a bunch of stuff. I would like to purchase a different rig for my outdoor/big indoor gigs. Some of my indoor gigs are for 1200 people.
Most of the stuff travels in a Chevy 2500 diesel van.
A Rig
APB Dynasonics pro desk
Ashley protea DSP and Digital EQ
QSC PLX amps
Mueller speaker double 18's JBL loaded( 4)
Mueller double 15's JBL Loaded ( 2)
Mueller single 10 & JBL 1''horns mid/hi's ( 4)
Lexicon and Alesis effects
Sennheiser,Shure,Audix mics
B Rig
A&H Mixwiz
Mueller single 15 JBL loaded
Mueller single 12 & horn JBL loaded
Ashley analogue crossover & dualp 31 BAND eq
Sabine dual 31 band eq
QSC PLX amps
Sennheiser and Shure mics
Alesis quadraverb
Big 'un
EAW KF650z (4) over LABSubs (4)
QSC and Yorkville amplifiers
Small 'un
Nexo PS10 (2) over JBL MP418S (2)
SSSSSPR**
Yorkville NX55p (2) over QSC HPR121i (1)
**Secret Squirrel Super-Simple Small Powered Rig
Mains/Monitors:
JBL SR4726x (4)
MRX 515 (2)
Yamaha cmv 12 (4)
Subs:
JBL srx 718 (4)
Peavey sp2 18 (2)
Amps:
Itech 6000
QSC 4050
Peavey GPS 2600
Yamaha CP 2000
Peavey cs 800
Mixers:
A&H Gl 2200
Mix Wiz 16:2
Carvin RX 800 powered mixer
Mics:
Audix d2 (2)
Atm 25
Sennheiser e 602
Sennheiser 504 (3)
Shure beta 58 (3)
Sm 57 (4)
Backline / other:
8 peice DW drumset with Sabian Cymabals
24 channel Whrilwind snake
31 band dbx Graphic
Peavey 35xo crossover
EAW JFL210 constant curve system over JFL118 subs
UX8800 processor
pair of 01v96 boards
QSC amps
Lots of uninteresting wiring and pedestrian mics
A couple pairs of Mackie 450s and a pair of QSC HPR122is
Two range-plug distros and 17 miles of 12ga SO cord
I actually have a fair bit of lighting gear at the moment too - 40 or so lekos, mostly Strand Centurys, a few Source Fours
A few pars
NSI 7532 board
If there will be an equipment budget this year (kid #2 is on the way, just bought a new minivan), next on the list is another pair of JFL118 subs and some LED pars. Looking at some of the Blizzard stuff.
Well my rig ain't much yet. Most of my gigs have been in theaters where a house rig is provided, and there's not much of an option to use anything else. But as I venture out of the land of musicals, I'm building what I can.
Analog FOH:
Console: A&H GL2000-432, Mackie 1402, Behringer 802
Processing Rack:
2-Art CS2 Comp/Lim/Gate
2-Symetrix 425 Comp/Lim/Exp (Thanks Phil)
1-Omnicraft GT4 4ch Gate
2-Ashly GQ131 EQ
1-Alesis MicroVerb
1-Alesis MidiVerb
Its not great, but works for the youth/community theater that I have been living in.
Digital FOH:
Console: Yamaha O3D
Expanded to 24 channels with:
2-SMPro PR8e (well a 2nd will be coming shortly)
1-16ch patch panel with the 8 on-board pres and 8 outs
First show will be the musical Assassins coming at the end of February.
Speakers/Amplification:
QRx115s
Yorkville PL12s (Came with a DJ rig I was paid with for a gig)
EV Evid SOS3.2
Crown UT2020 (Rebrand of the CE2000)
QSC 1400
Ashly FTX-2000
Transportation:
1999 Chevy Cavalier - Thought I had an SUV last summer but that turned out to be a giant turd. Looking to upgrade in the coming months. If you're into Facebook stalking I've got a few pictures of the Cavalier packed to the GILLS I did with Phil's racks and stacks.
Basically prior to this winter my focus had been on supplementing house rigs in theaters with better/more reliable gear when I had to mix. Thus the mish-mosh. Most was stuff that had just been acquired thru my high school/college years. The 2011 goal is to build on the FOH stuff to improve the quality of processing and then partner with others for racks n stacks.
Current A-Rig
2 x Peavey SP-3
2 x Peavey SP-218
1 x Crown XLS 802 MF/HF
2 x Crown XLS 402 LF
2 x QSC RMX 2450 Subs (Heavey amp rack! Hello hernia surgery!)
MONS
Current wedges are 4 x Yamaha. Almost done building my Proprietary wedges (already have amps and processing.) Once they're done, it'll be:
4 x Biamped Proprietary wedges 12'' & 1''
2 x QSC GX3 HF
2 x QSC GX5 MF
Yamaha ls9-32 (Finally sold my gl2400)
32 x 8 RamLatch multipin snake
Current B-Rig
2 x QSC K10
2 x Yamaha SW118v
I use my LS9 for my B-Rig as well
32 x 8 snake
My thoughts on the Peavey SP Rig: Big, Heavy cabinets that aren't constructed very well and get loud very easily. My DSP EQ is chopped to hell to make them sound good. This may be because of the amp combo or maybe that's just how it is (any thoughts/suggestions?)
My thoughts on the QSC K-Series rig: I absolutely love it. My first time using them I used no DSP and pulled a touch of 500Hz and 6.3kHz out and they sounded great out of the box, IMO. I used them for monitors the next day and I didn't like the angle that they were at, so I put a DI box under it to prop it up a bit more. Other than that, I love them. Very very lightweight too.
I'm currently in the process of selling my entire Amp rack and SP-3's if anyone's interested.
Replacing them with 2 x ev qrx, qsc plx mains, crest pro9200 subs.
I pull everything with my dodge ram 1500 5.7 hemi. It has the full tow package which has the extra radiators. It pulls my 6x10 trailer w/o even breathing. Gas mileage while in Tow/Haul mode is ''eh.'' I would say 12-14mpg. W/o the trailer, on the highway, I've gotten up to the high 20's due to the cylinder shut off feature.
Let me know if there are any suggestions to my set up! I'm always up for anything.
-B
Consoles:
Allen & Heath ML3000 40ch
Soundcraft Series 2 40ch
Allen & Heath GL2400 32ch
Outboard is dbx and lexicon
Speakers:
(20) Versarray 112's
(8 ) Versarray 218's
(4) QW4's
(4) QW wedges
(8 ) TRX wedges
Amps:
FOH is all Crest Pro 200
Monitor is all QSC PLX
Snake: EWI 32ch roller with split
Mics, stands, cables, cases...blah blah blah
A-Rig
EV XLc-DVX Line Array
Yorkville TX9s Subs
DX46 Process / KT DN360b Graph
Square-One Dynamic / Drawmer Gates / Ashly and DBX Comps
SPX2000 / SPX1000 / M-One / Dtwo (on disconnect)
EV P3000 / CP3000 Amps
Crest 9001 for subs
Rig comes standard with Midas Verona 480 and Sienna 400
But digitals are available (and often used these days)
CBI 42x14 Split w/ Mass Disconnect
Ashly GQX3102 x4 for mons w/2 Comp/gates / 1 Lex FX (on disconnect)
EV Xrray XW15b wedges / LS800PB's for drum subs
Crest Pro8200 / Pro7200 with Ashly Protea 4.8S for Process
International 26' Truck
B-Rig
EV QRX153/75
w/B&C 15'' drivers we replace as soon as we get them due to the weak driver it comes with (we used to have TX4's so we got the same 15'' and its killer)
Yorkville TX9s
Ashly Protea 3.6s for process / KT Square-One for FOH Graph
Crest CA6 / CA12 / Pro9200
EV ZX3 and ZX5 for mons
Crest CA9's for wedges
GL2400-32 / GL2800-32
DBX 1231 for mons
Chevy 3500 16' Box Truck
I only have one setup, it's worked well for any bar shows and all ages shows I've done...
Yorkville:
FOH
2 - U15's
2 - LS800P's
Monitors
4 - YX10's
Mixer
Yorkville powermax16
16channel powered snake
Rack:
YP800 for monitors
2 - 31band peavey EQ's with FLS
1 - 15 band x 2 peavey EQ with FLS
Yorkville UP processor
Dual channel Rocktron compressor
Mics:
4 - SM58
3 - SM57
3 - PVM 480
5 - e604
2 - e614
1 - e602-II
Cables, stands, DI's etc.
It all fits into my quadcab Dakota. That being said, I'm looking for a 5x8 trailer that will fit into my garage. As a one man show, it's a pain looking for help to load the subs into my truck. Everything else I can do by myself. A trailer would allow me to do it all without any help. And the other issue, is loading everything back into my garage after a gig at 3 in the morning. With a trailer I could back it into the garage and leave it there for the next gig.
My wishlist is the trailer, and a StudioLive 24.4.2 one of these days I'll bite the pulley and pull the trigger on the SL. It's a nice little setup, does pretty much why I want, and sounds good doing so.
''A'' rig
FOH:
Yorkville U15B tops over UCS1B subs (2 each)
Amps: All QSC
PLX3102 bridged to subs
PLX1804 stereo to tops
Speaker Processing: dbx DRPA
dbx 231EQ
Monitors:
Yorkville E210B front line (2)
Yorkville NX20 bass & drums (2)
Amp: PLX 2402
dbx 231EQ
Mixer: A&H GL2400-24
FOH racks:
FX: Lexicon MPX200 (2)
Comps: TC Electronics C300 (2), Behringer MDX 4400
CD player: Numark CDN15
Snakes: Whirlwind 100/16/4 & Mini 6-25, Proco 100/24/8 & 50/6, and custom 30/4
Mics: Shure Beta 58, Beta 87, SM58, SM57, Beta 56, Audix D6, i5, ATM25 Pro, CAD SA2000, EWI C61 (now C300).
''B'' rig:
Varies dependent on need.
Same FOH & amps may be used with the monitors as mains OR just a pair of Mackie SR1530s for mains.
Small mixer: Peavey RQ2314
''C'' or DJ rig
Mackie SR1530
OR for super lightweight, NX20s on stands with some unknown brand 15'' plastic subs from eBay powered in mono off a split QSC GX3.
Mixers: RQ2314 or a baby Behr UB802 (2 mic, 2 stereo channels)
CD player: Numark CDN25
EQ: dbx231EQ
Additional mic for unknowns or DJing: Behringer XM8500 and some ultra cheap Nady wireless Duo;>)
Mike McNany
Nice new forum here... Should be good!
Here's what I have - and mix & match as needed...
Mains/Monitors/Subs
2 Yorkville U15P's
6 QSC HPR122i's
2 QSC K8's
2 Yorkville UCS1P's
Mixers
A&H GL2400-24
A&H MixWiz
Snakes
EWI 150' 24+8
100' 17+7 (unknown brand that I modified for use with the MixWiz)
50' ''DAP Audio'' 12+4 (usually used as a sub snake on larger stages or for small set-ups)
Rack
a mix of DBX EQ's, crossover, compressors, Lexicon FX unit, etc...
Mics/DI's
The usual SM58's and 57's, Beta 58, Audix OM5, two Audix D6's, D4, two D2's, two i5's, three Sennheiser E604's, four ATM450's, Audix wireless system with OM5, and a variety of other stuff... Radial and EWI DI's. Most mic stands are Atlas...
Cables
EWI and Rapco, with a few other brands thrown in...
Lights
A mix of PAR56 and PAR38 cans, and a variety of LED lighting, DMX controller, etc...
Love the Yorkville Unity stuff, and very easy (and cheap) to rent more around here as I need it. In reality (especially over the winter with smaller inside gigs), the QSC's get used far more as mains - but revert to monitor duty for bigger shows.
Usually this stuff gets hauled around in my Chev Express 3500, and I rent a U Haul 6x12 trailer if I need more space. Occasionally I just throw the K8's, the MixWiz, and a few cables and mics in the trunk of my Saab for a small gig.
I do a lot more reading than posting on most forums, but I might as well make my first post here with my rig.
Current Bar rig, all fits into a minivan:
FOH:
EV QRX 115/75 (2)
2010 JTR Growlers (2, waiting on 2 more to be delivered)
Yamaha wedges (5)
Amp Rack:
Driverack 260
QSC RMX 850
QSC RMX 1850hd (2) > awaiting a QSC GX7 to use for QRX lows
QSC RMX 2450 (2) > bridged mono per sub
Carvin DCM2004L - 4 channel monitor amp
Mixer/FX Rack:
Yamaha MG206c Mixer
DBX 231 EQ (3)
Lexicon MX200 FX
Mics:
EV nd767a (8 )
Shure SM57 (8 )
Shure SM58 (4)
Audix D6 (1)
Sennheiser e604 (3)
Whirlwind IMP2 DI (4)
Fostex MC10 Condenser (2)
I also have JBL JRX125 cabs for rental, people love that orange badge.
Future equipment I am considering:
Allen Heath Gl2400-24
JTR Triple 12s (2)
QRX 115/75 (2)
Yorkville LS808 (2)
The above future equipment will allow me to have two good bar rigs working at the same time and allow me to mix and match equipment in order to best fit the needs of more gigs expanding the work I do both indoors and outside.
