Re: Which limiters are good enough?
If you want your limiters to actually protect your speakers, then you want your attack time as quick as possible. I like 0ms attack time personally. Release time depends on what you want your limiter to sound like. A longer release is going to pump more, while a short release time is going to be "choppy" sounding. My release time normally hovers around 80-90ms. Gets out of the way fast and sounds fairly transparent.
Output gain should be at 0. Adding 10dB of gain to your rig is going to completely change your gain structure and make your limiter setting completely useless. That 10dB(or whatever) of added gain is going to make your amps clip 10dB before your limiter even kicks in.
Thanks, I really apreciate all the help you guys have given me, any ideas on some pretty good limiter settings? I thought about these :
Attack Time : 1-5ms
Release Time : 100ms
Ratio : Infinity
Threshold : I turn that down until the amps stop clipping (when setting gain structure without a load connected to the amplifiers)
Output Gain : whatever number in db that the threshold has to be set to, so if the threshold is -10db (just an example) then the output gain would be set at 10db.
Is that right guys?
