Would you use 16g installation speaker cable for power amp to patch panel?
I have to wire a new rack and have a bunch of this laying around. I usually use regular 14g portable speaker cable but would like to use up some of this lighter stuff.
BJ
Theoretically for the short patch run, 16 AWG shouldn't have significant impact on power loss and damping. However, I personally feel better using thicker wire even for the short sections like the amp patch panel and the speaker box terminals to the drivers. But that's just me. I believe I'm using 12 AWG for both.
Greg
Open up your speaker cabinets and check the wire there. You'll likely find 16 or 18 gauge wire inside.
It will be fine, but the stiffness of the wire can be a pain, so I prefer to use SJ. I use the same 12-4 I use for cables - why have two types of wire on hand? To make reconfiguring faster, for connections to the amps I use Deltron banana plugs (Mouser 174-5791 (black) and 174-5795 (red), as these are the best I've found.
Hey Tim, I think everyone uses SJ for speaker cables. There is no logical reason or code why anyone would use SO for that application. Last amp racks I wired used portable 13/4 speaker cable in the rack, but I've also used 14/2 install speaker wire for things like that.
I don't use banana plugs anymore since even the 'professional' ones (I was using ProCo) seem to fall out once in a while, and I don't have time to troubleshoot things like that at a show. I want it to work every time without exception.
Each of my amp racks contains two IT5000HDs, and with this configuration I haven't ever found a need to reconfigure anything. I have two NL4s on the output panel wired straight-through to the NL4s on the amps themselves. This covers every biamped speaker I could ever use. For any non-biamped speaker, I have a little box that breaks out a single NL4 cable into two separate feeds, one per amp channel. Additionally, I have cable that would take two NL4s and make them into one NL8 if I ever needed such a configuration.
I'd much rather have a standard configuration at every show which I can rely on to always work than ten different configurations which I have to double and triple-check at a show before I can be certain things are going to do what I expect.
One thing that I started doing (off topic from speaker gauge) was putting two conditioners in each rack. Most of the gigs fall in to that category of venues where sound reinforcement was never intended. So power is always and issue.
The point is, you're not conditioning shit. Even if you bought a Surge X you'd just have a really excellent surge protector. That's not conditioning. The only conditioning I've ever seen done is by a bottle in my shower labeled "Herbal Essences". What conditioning is in the context of power distribution I have no idea.
What you're really doing is putting a 15A circuit breaker between your amps and the wall outlet's breaker. You're also introducing some MOVs, and maybe a power switch.
Don't you need hair for that to work?The only conditioning I've ever seen done is by a bottle in my shower labeled "Herbal Essences".
