Re: Dual X32 setup
From what I've read on this, you only need a single cat 5. However, having a spare ready to rock in case of failure of the first cable isn't a bad idea. I'd also have the show saved on USB so that in the event of main console failure, you could easily move the show directly to the other console.
This is probably the single most exciting feature I have seen about this console, as I regularly run a monitor/mains setup. This greatly reduces my hardware needs and gives redundancy of an item that rarely is available in smaller shows.
I think you want to run 2 lines cat 5 to allow for redundancy
