Well it's a "proprietary horn design" so I doubt we ever will.Very interesting.... they maid it trap... would be more interesting to see the inside
Hi Don,
The clarity at 200ft was unreal, especially when compared to the vertec.
To be fair, you have a point. It is very different. It's not why I'm displeased, though. If you look back on their Facebook page at some of their posts while developing them, their target crossover, efficiency, and all of their components clearly started from Peter Morris's design. It's ended up being the same efficiency, having an arguably worse crossover frequency, heavier, without a pole mount, larger, and in my opinion uglier. It's just not in the spirit of what Peter created and posted, and they've clearly taken his component selection and pass band intuition without giving what I'd say is an appropriate nod. The only thing I like about them is that they are, in fact, trapezoidal, and that their larger horizontal horn mouth means that they will maintain their directivity about an octave lower than the traditional PM60 design.How is the Henessy design even remotely similar to the PM60? Beside the fact that is it a MTM horn loaded design, there are several significant diffrences.
Peters design is not the first box ever made with similar performance. OHM HDMH box is like 15 years old at least. Our M28LA line array box was released in February 2014. Check this topic starting date.
If you use that analogy, every reflex box ever made is a copy? And they should all be pretty much same? But they are not.![]()
Thank you Peter.
Looks fantastic! Quality construction.Dear all, thanks!!!
Spent a long week in workshop building PM90, here are my results
cheers Ivan
View attachment 208771View attachment 208770View attachment 208768View attachment 208766View attachment 208769
