Hi Christian,
nice to have you back here.
There is a lot of marketing going with the new board, but not many details.
I would love, if you could change this:
Do you like the new channel strip compared to the X32 ? Because I feel like I will miss some things like LED encoders and Bus sends on pots.
Does SoF work like X32( both directions ) ?
Is it correct that Aux channels have less processing compared to standard channels ( similar to missing comp on X32 ) ?
Can the console do bus to bus routing ( you might have seen the discussion on PSW about FX returns )
If the Gain is part of the source, is it correct, that I can set up tie lines with gain ?
Can the console do channel to matrix routing ( Yamaha style ) ?
What is the default Cue for the Solo Bus, if no Solo button is pressed, or is it possible to define that ( Back ground: there are 4 Masters )
Have fun with the new toy
Uwe
Uwe
