So I have a bluegrass festival coming up in August and I don't have much experience with this genre...any tips and tricks from you all?
Thanks!
Jared
Thanks!
Jared
Thanks!
Jared
Thanks!
Jared
Shure / Beta58A (QTY 7) |
Shure / Beta57A (QTY 3) |
Shure / Beta 91A (QTY 1) |
Shure / ULXD4Q (QTY 1) |
Shure / ULCXD2 (QTY 1) |
Shure / ULXD1 (QTY 1) |
Shure / SB900-8 Battery Pack (QTY 8) |
Shure / SB200-US Docking Charger |
Shure / SB200 Docking Charger |
Shure / WCE6IT Country Man |
Shure / SM58 (QTY 2) |
Audix / DP7 - Audix 7-Mic Drum Mic Package (QTY 1) |
Audix / ADX51 (QTY 1) |
Heil / PR40 Bass Guitar (QTY 1) |
Heil / PR30 Guitar (QTY 1) |
Beyerdynamics / M88 TG (QTY 1) |
Sennheiser / MD 424II (QTY 1) |
Countryman / Type 85 DI (Bass & Keys) (QTY 4) |
iSEMcon / Omnidirectional Real-Time Analyzer Microphone (QTY 1) Shure SM58 x4 (QTY 4) Shure Sm57 (QTY 4) AT Pro37 (QTY 2) Audix DP5 Kit (QTY 1) Heil PR22UT (QTY 2) Sennheiser E945 (QTY 1) Sennheiser E935 (QTY 1) MXL 2001 (QTY 1) I didn't have a specific question at this time, just wanted some general info. I appreciate all the insight so far. |
Three things that immediately jump to mind are:
Set up a separate MC mic on a stand at one side of the stage. If you don't it is guaranteed that the mc will talk and talk and talk when you need to be moving that mic for the next act.
Route your channels so you have an instrument group and vocal group. Dropping the instrument mics 20 db between songs goes a long way to clearing up the spoken portion of the show.
Set your system eq for the foh and wedges according to what the individual mics need. Then have a separate channel for the LDC and insert an extra eq on just that channel. That way you are not scrambling to change between the LDC and individual mics.
If you can manage it extra speakers as sidefills work better with the one mic technique and also help clean up the wedges which typically overlap too much on most festival stages for my taste.
You didn't say if this was regional acts or national acts but that will also determine the level of expectations.
Sent from my DROID RAZR HD
Headliner is a 2014 Grammy nominated band, the rest are regional.
How much excruciating detail do you want? As Alan H intimates, this is an easy genre to screw up. If you do it right it can be some of the most musically rewarding work you'll do.
First: bluegrass is a fairly intimate genre, I call it back porch music. Your job is to take that intimacy and interplay and share it with the audience; you spread the love, so to speak.
Second: that means "don't rock and roll". Don't add HF to the mandolin or fiddle, you probably don't need to put a hump at 60Hz in the bass. You want the instruments to sound acoustic. If you don't know what the instruments are supposed to sound like, hire a mixerperson who does. You're screwed without familiarity of the instrument sounds. "Don't Rock" also applies to overall SPL. It's inappropriate for the genre and can give you ulcers fighting the feedback.
Third: count on 2 types of bands - the single mic (usually a LDC, AT3032 is popular, I use a Rode NT2) and "mic everything". We address the latter with what we call "pods". A pod consists of 1 vocal mic on a tall boom stand, 1 instrument mic (AT4041, AKG C-391, Okatava MK102) on a medium boom, and 1 active DI (Countryman FET85 or Radial J48); we have 4 pods across the downstage, 2 pods mid stage left & right. We also dedicate a line for upstage bass players and 3 lines for bluegrass drummers. The mid-stage pods can be moved around as necessary. You might get a hybrid act, one that uses primarily the LDC single mic, but wants 1 or 2 "walk up" mics for solos.
Fourth: have someone be your stage mic wrangler if you're doing monitors from FOH. This person needs to meet with a band representative well before they go on and suss out the stage plot and to tell the players "don't randomly grab mics, please stand where you'll play, and I'll put the mics out; feel free to position them to the sweet spot on your instrument." Give your wrangler a lavalier wireless mic and use your headphones to listen to him/her, and use talkback thru monitors to communicate with the stage. Have your wrangler on stage when setting monitor levels (you can hear what you're doing over his lav mic, just for a reality check) to translate from "bandspeak" to "tech".
There are several folks here that mix bluegrass and related genres - Jay Barracato, Dick Rees, John Halliburton all come to mind right away. I'm sure you'll get lots of advice. Do you have any specific questions?
Your "mixing" will vary from band to band. Bands that use a single mic could be just that one mic for everything, no mixing there on your part other than to get the needed gain on the mic. Some one mic bands will use a separate input for the bass, the type of bass could be anything.
Bands that that go with individual mics for vocals and instruments may need to be "mixed" or some bands will individually work the mics mixing themselves, if you get any band who work the instrument mics to mix themselves find the average level for each of the instruments and let them do the rest.
Bands going down the modern bluegrass road may have pickups in the instruments complete with pedals and amps.
In the world of bluegrass when a musician takes a break it's a solo not stepping out back for a smoke and a drink!
Jared,Thanks all for the advice.
I currently have in my mic locker:
Shure / Beta58A (QTY 7) Shure / Beta57A (QTY 3) Shure / Beta 91A (QTY 1) Shure / ULXD4Q (QTY 1) Shure / ULCXD2 (QTY 1) Shure / ULCXD2 (QTY 1) Shure / ULCXD2 (QTY 1) Shure / ULCXD2 (QTY 1) Shure / ULXD1 (QTY 1) Shure / SB900-8 Battery Pack (QTY 8) Shure / SB200-US Docking Charger Shure / SB200 Docking Charger Shure / WCE6IT Country Man Shure / SM58 (QTY 2) Audix / DP7 - Audix 7-Mic Drum Mic Package (QTY 1) Audix / ADX51 (QTY 1) Heil / PR40 Bass Guitar (QTY 1) Heil / PR30 Guitar (QTY 1) Beyerdynamics / M88 TG (QTY 1) Beyerdynamics / M88 TG (QTY 1) Sennheiser / MD 424II (QTY 1) Countryman / Type 85 DI (Bass & Keys) (QTY 4) iSEMcon / Omnidirectional Real-Time Analyzer Microphone (QTY 1)
Shure Sm57 (QTY 4)
AT Pro37 (QTY 2)
Heil PR22UT (QTY 2)
MXL 2001 (QTY 1)
don't over-mix. Once the basic levels are set, most Bluegrass bands know how to get in on their mics during breaks and fills. You probably won't be able to keep up with then anyway. Good eq is more important than volume.
Absolutely. Enjoy the show. The good EQ part is don't have any feedback or wind noise. Unlike the local rock word: 1) most of these guys are great musicians. 2) Most of these guys have a good instrument tone. 3) The stage volume is always reasonable. 4) The band sounds the same "unplugged" so remember you are "capturing" the sound and not trying to make the tone with EQ.
Every time I have a Bluegrass act I remember what comedian Steve Martin once said,“The banjo is such a happy instrument--you can't play a sad song on the banjo - it always comes out so cheerful.”
Good advice. I call it Hippocratic Mixing - first, do no harm. Or perhaps "organic" might be better...
Re the banjo. At a festival a few years ago I saw a lady wearing a t-shirt with a depiction of The Scream... stalking up behind the screamer was a banjo player.
The banjo - lollipop of love, or weapon of musical destruction? Film at 11.
