Re: Danley SH96HO
I am with Ivan in this too. It is not a simple answer. Any simple answer will be wrong.
If i tell you that in some of my boxes the crossover is set at 3.5Khz that will be true to the point when you measure the HF and you see that it actually goes down to 1000Hz.
So which answer is the right one? 3.5KHz or 1000Hz. That is a very wide band we are talking about.
And then there is the LPF that Ivan talks about on top of that that is at about 7.5Khz.
So pick any of those 3 points. They are all correct.
