Re: Digital Console purchase for a 400 capacity theater
I was really impressed by the ql5 in that price bracket.
Sent from my XT1254
Sent from my XT1254
The A&H Dlive was next and it is really impressive. Even the baby brother of the line, the S3000 is superbly packaged. Whereas the Digico UI puzzled and confused me, the DLive is a console you can walk up to and mix on within minutes. It's really intuitive. Mapping of inputs to channels and channels to faders took a minute or two to understand, and there were some touch screen gremlins, but at that point, you can lay out the console however you want. Effects are easy to use, sounded great (on headphones at least) and are easy to bring into the mix. Much like the predecessor ILive, the DLive consoles are just controllers, all the DSP is in the stage box, meaning each console requires one. However, the inverse is not true - a stage box can be used by itself via an Ipad. Cool idea for small shows.
Greetings everyone,
I need to spend some more time with the Yamaha CL and GL consoles before I can come to a conclusion. The CL is capable and solid, but may be too expensive for me. The GL looks promising.
I think you mean CL and QL. I don't know of a GL console from Yamaha...Just A&H![]()
On a slightly related topic, can anyone familiar with the Midas Pro2 talk about ease of use? I am concerned that the BEs we see - having wildly differing talent and ability - are going to need more assistance learning the Pro2 interface than a DLive or QL. Rider friendliness does not concern me greatly, a capable engineer can get good sound out of many consoles, but ease of use issues are harder to overcome.
Cheers,
... Midas Pro2 for monitors... I can't say it really impressed me, it did what I wanted, but had me scratching my head enough times to make me leery of the complexity. Even with a show file created in advance, there were two last minute IEM additions that required some non intuitive steps. And the way it uses the screen real estate was odd, for example, the channel controls stay in a little band on the right side of the screen which made the PEQ particularly awkward to use with any detail.
Cheers,
Simon
Folks,
Still working this project, but until the fund raising is finished there is little to do.
We had an eleven band event this past weekend and brought in a Midas Pro2 for monitors. Was an ideal event to learn how the console works and spend some time actually using it in battle. With the show behind us, and a bunch of happy musicians still talking about it, I'm digesting what I think of the console after using it for 14 hours. I can't say it really impressed me, it did what I wanted, but had me scratching my head enough times to make me leery of the complexity. Even with a show file created in advance, there were two last minute IEM additions that required some non intuitive steps. And the way it uses the screen real estate was odd, for example, the channel controls stay in a little band on the right side of the screen which made the PEQ particularly awkward to use with any detail. I'm not averse to the console, but it didn't impress me in any way.
Other random thoughts.
The A&H DLive proposal is dead in the water until they publish an Ipad app. Anyone have any news?
The Soundcraft VI3000 with 48/16 built in IO fits our channel count requirements nicely. I didn't look at it closely before because I thought the entire Vi family required external IO which was going to push them well out of our budget. I suspect it's still too expensive, but does anyone have pricing?
The Digico SD9 also fits with a pair of D-Racks, but the UI takes some getting used to and I suspect it's also too expensive, unless there are a pair of used ones looking for a new home.
I'm working with CBI right now to refresh our copper split snake stage boxes and fanouts. That will be a huge improvement.
Cheers,
Simon
FWIW: Midas has "that sound" with it, unable to describe what it is in writing, but every time I plug a mc into it it just sounds "better".
Same with Digico.
And last night, I did a festival on a SSL L500 mixing all the bands. Never seen the console before, 6 acts, no sound check, just line check and ASAP changeovers. Sounded really really good, nice workflow and I found my way around it quickly. It also has "that sound", so I'm really looking forward to mixing on it again.
to me all the new boards from quality manufactures sound great in 2016.
Folks,
Cheers,
Simon
Hi Simon,
Check out the SD9 with a D2-Rack of 48/16 (expandable to 32 outputs). It might be within your budget, it costs less than a SD9 with a pair of D-Racks.Eytan
