MiniDSP is great, but it doesn't provide a great solution for pro audo loudspeaker applications. Does anyone have a good solution for a FIR capable DSP with balanced line level I/O?
Thanks.
Thanks.
I saw that, but I'm really looking to do FIR taps for this project.If it's just balanced I/O you're after, there is a balanced version of the Minidsp. Although the webpage claims IIR only, the manual has information on how to load custom biquad filters.
[/URL]
So they have all the features required make perfect settings for the your PM boxes.As a crossover / processor absolutely. I think I'm getting even better results![]()
The Lake may still has advantages in terms of being a system tool with its groups, Mesa EQ and its easy to use brick wall filters etc.
There is also the DRAC-88 series which use the miniSHARK module for FIR processing, its 8 in 8 out both balanced and unbalanced.MiniDSP is great, but it doesn't provide a great solution for pro audo loudspeaker applications. Does anyone have a good solution for a FIR capable DSP with balanced line level I/O?
Thanks.
There is also the DDRC-88 series which use the miniSHARK module for FIR processing, its 8 in 8 out both balanced and unbalanced.
At that price point, we're well into the professional market. Defeats the purpose.There is also the DRAC-88 series which use the miniSHARK module for FIR processing, its 8 in 8 out both balanced and unbalanced.
Hello. I am planning between opendrc Di and blu 16. I have just bought minidsp and I am planning to return to sellerI have got the BSS London BLU-16 of off the ebay for $260 and tax, and the extra output card for arroud a hundred. Not diy but not that much more than minidsphd plus the rack drawer, balanced to unbalanced converters and the converters other way if to buy all that stuf. Also blu has less limitations on fir taps usage. Bss audio architect does accept .csv export from popular software packages. I don't have four ways system, so I did set Vrx932la plus a sub for a test as a three way. Got pretty decent impulse response. Phase is within 40 deg down to 100 Hz and within +/- 7 deg from 300 to 20k, not too terrible for the first try. Crossovers are 96 lr at 1k and acoustic lr 24 at 85 Hz for sub, with some iir flattening before fir filters.
Just to see the DSP usage i added another pair of ways to make it into four ways.
The blu16 now is set with three inputs and eight outputs. Each of the mains consist of input gain, delay and system eq set all as stereo pair, the super high channel with another parametric eq , delay, fir filter, limiter, gain. Highs are similar, but uses bss crossover set as high pass lr 24 at 800 hz to clean up the low end of the fir. The crossover also includes delay and gain controls. The lows uses parametric eq down low, linear phase lr96 fir on top and the stereo crossover at 85 hz. Driver time allignment is implemented as a delay inside the crossover block.
Input 3 is for aux fed subs and feeds two of the otputs with delay between them to set the radiation pattern. It also features shared gain control with mains, parametric eq, and the crossover with subsonic filter and limiters.
The limiters are of two stage variety, suposedly peak and rms but bss is little unclear on to which of the stages the controls belong to.
My Fir filters have 820 taps at 1 khz crossover and 320 taps at 3 khz (not in use with vrx), to keep overal delay under 10 ms. Maximum of 6700 fir taps can be specified , I don't know if per filter or total.
All of this did put DSP utilisation to 80% or so.
Access to the unit is over the wired ethernet, but wifi via router works just fine.
Hope this helps some...
I’ve got the fir crossover built into my 4820 LR amp.The advantage of the Lake was its ability to do linear phase crossovers, both brick wall and a FIR LR 24dB/Oct slope. To my ear things with a flat phase response sound more real.
The PM 90/60 works best with the 24 dB slopes to maintain vertical pattern control as narrowing low frequency band is merged with the widening HF band at the crossover point.
The ASC48 will do a new LIM 24 dB/Oct linear phase crossover with less issues than the Lake FIR simulation and you can overlap the bands if needed. The latency associated with this approach can also be less and you can cross to the subs with a linear phase crossover and have a latency less than 15ms .... which I think is about the maximum for many small applications. Here is some info on this approach ...
http://linea-research.co.uk/wp-content/uploads/LR Download Assets/Tech Docs/CrossoverFilters White Paper -C.pdf
The thing that is great with the Lake is it EQ page … almost unlimited filters of any shape you want.
You can see some of them on this video
In terms of price it cost me about half what a Lake would cost and it is 4 way stereo which requires 2 x Lake LM26’s.
I bought mine for Audio Bands Australia - http://www.audiobrands.com.au/ Don and his team are great![]()
