Re: Does this product exist?
The network latency besomes unstable? Or you just have a variable latency depending on which points on the network you measure between?
NO NO NO!!! It doesn't matter if you are using CobraNet or Dante, DO NOT "DAISY-CHAIN" your network!!! Think "STAR" instead...
The problem is that when you link too many network switches in a chain, the forwarding delay from one end to the other becomes too unstable.
Of course, we all know that Dante requires at least a Gigabit network, and you are limited to about 6-7 network switch hops.
CobraNet, on the other hand, with a old-school 10/100 network is also limited to about 6 network switch hops. However using a current technology Gigabit backbone in your network, you should be able to do several more than that.
Regardless, you need to remember to build your network in a star configuration, not a daisy-chain!
