inuke 6000 clipping
carl brooks
7
Hi guys, I have a inuke 6000 running a pair of behringer 18" subs, and a qsc 2450 running a pair of yamaha full range speakers. on my mixers output meter it goes from green to to yellow to red. I was at the club fri. running sound for a band and the meters where in the high part of the yellows. and the inuke's cliping meters were pegged the qsc was running normal. it sounded good. but am I going to fry the amp this way? i had to turn it down quite a bit to stop the inuke from cliping. when i first got the amp i tryed running the pair of subs on one channel and the yamahas on the other, and the amp would go from amber to red around the volume knobs, and cut out for a second. then back on then off again until i turned it way down it doesent seem to like a 4 ohm load . all speakers are 8ohm. any ideas? thanks
Re: inuke 6000 clipping
You're not"turning it down". You're adjusting the signal input level of the amp. It puts out its rated power regardless of the position of the knobs. The knobs simply regulate the incoming signal so you can keep it out of clip.
That said, different brands clip at different levels. They may also have differing input sensitivities. You have to read and understand the specs.
During normal operation, you should NEVER see clip lights. If you do, then you don't have enough rig for what you're doing. During setup, you could drive it just so that you see the clip lights flicker, but that's it. If your clip lights were pegged, you are doing it horribly wrong. Learn to fix it.
If you drive the amp too hard, it will shut itself of to try and protect itself. It's not that the amp doesn't like a 4 ohm load, it doesn't like what the user is doing to it.
You do not mention a crossover? How are you processing the feed to the sub amp? Trim levels there.
from what i have read , You need to start at the board and get everything adjusted to 0. it sounds like you are clipping at the board first and that IMO is whats making your amps peg out. google things about gain structure, That will help you out a lot. It did me. :) Hope this helps.
i replaced a stolen qsc 2450 with the inuke i took a chance seeing that inuke is very lite. But the qsc performed great only clipping when i pushed the system hard. it blew a jbl 18" sub once. But anyway I run through a older loft crossover gains at 3/4 up. and the inuke gains all the way up. I played with the gains before but seemed like i was loosing alot of volume. I will try again. Thanks for the help
Once again, those are not "gain"pots on the amp.
:) Sweet I designed the Loft crossovers, about a hundred years ago......
ok, those "Gain Knobs" are not for gain. Back those down to about 3 o clock. your over driving your system by doing what your doing , if you dont have any limiting then chances are your on the way to blowing something. a lot of people go through this , but it can be worked out and your system will love ya for it. lol
I find neither a gain nor a sensitivity spec in the NU manual.
Here is a quote from the guy 'teslaman' who did the famous inuke6000 tech review:
teslaman said:
Gain is 42dB with controls at maximum and therefore for full power you need an input of 0.82V rms for full power into 8 Ohms or 0.71V rms for full power into 4 Ohms assuming music conditions.
These figures also tally with my measurements for output power vs input voltage (which I didn't publish as there not really of interest!)
Full story here: http://forum.speakerplans.com/behri...am-kxd7200-bench-tested_topic69202_page1.html
JR: Can you translate this into dBu@peak voltage? My audio math isn't that good...
I have worked on (as in bench tech repaired) A LOT of gear over the years. But never had a single piece of loft gear come in for repair. It just always seemed to work :)
I guess that says something for the design---------------------------
The only thing that turning down the gain knobs on the amp will do is to increase the dynamic range of the system a couple of dB max. I REALLY don't think increased dynamic range is of any concern in this case.
He needs greater output-NOT less noise.
At least that is the way I see it---------------
OK log math is additive so 42dB is the same as 40 dB (100x) times 2 dB (1.258x) so assuming he is talking about voltage ratio and not power ratio the voltage gain would be 126x. Now if he was talking about power ratios we're talking a lot more. :-)
There is a 402, 403 and 602 on eBay for sale.
Keep in mind those have to be 30 years old or more.
IIRC the 602 was switchable between 4 pole Linkwitz Riley and 3 pole Butterwoth, while the even older 402/403 were all fixed 3 pole Butterworth.
I suspect you can buy a more modern actual DSP used, for close to the price of those (surely tired) old soldiers.
Note how I didn't even put a knob on the frequency control so users couldn't mess with it after set up. :-)
Backing down the amp knobs will do nothing if the mixer output is then increased to make up for the lost level.
Well, Yeah , i mean he has to start there first , Thats why i suggested to google gain structure.
So I was a bit bored and I drew up a thing on my friendly neighborhood whiteboard. Ignore the free field thing - the literature says half space, but it seems that it would apply in a club environment more or less.
It's crude but the interesting thing is that (assuming I'm doing my math right and have any clue what I'm talking about) you should be getting plenty of SPL from those boxes, such to the point where I'm questioning why you need so much that you're clipping the amps to get it. Now, I've assumed that you're using the B1800X-PRO subs in your case. Their literature suggests that the iNuke 6000 should be loafing around a bit.
So. Either I've screwed up or you're doing one of the following:
-Your crossover is set too high; the B1800X literature requests you crossover at 175.
-You've somehow provided the iNuke with WAYYY more voltage than it was designed to take in and need to cut that down.
-You've not taken the time to make sure your system's tops and subs are balanced with each other. I don't know what your tops are, but I'd be willing to bet that they do not operate at the same level as your [b-word] subs.
I dunno... something seems terribly wrong.
Lets start with trying to find out what signal levels we are operating at here.
What is the name of the mixer and what does the meters show?
Given the sensitivity of the amp and knowing that mixers are often capable of putting out a signal level that is 24 dB above what the amp needs for full power, there is a lot of room for error here.
