Is iLive the biggest/best digital for the money?
Re: Is iLive the biggest/best digital for the money?
Apperantly there is a difference in the price points in the US, Europe and elsewhere.
I also didn't put the M7CL in the same budget ballpark. (minimum 30% more expensive in the 48 channel version and still lacking the multicore, which is a big downside here, where truckspace and -weight is much more expensive).
So in the same budget there are essentially the LS9, the Si compact (both less expensive but without the snake), the Roland M480 + stagebox (roughly the same money for the package). Out of the 4 I would take an iLive system any day.
But maybe the question is slightly off by asking about the money to spend and not so much about the money to earn (riders etc.). So spending more money can result in a better ROI and thus be less expensive in the long run.
So in the uk :
the m7 lists for £25k
Ad the t112 with an idr48 lists for 11k
(prices are ex vat)
This is well under 1/2 the price and includes digital multi...
So in the uk :
(prices are ex vat)
Definitely a difference as when I have compared roughly comparable M7CL-48ES and iLive-T systems the A&H option is usually less expensive than the Yamaha but not by nearly that much of a margin.
Brad -
The US SUGGESTED RETAIL of the iLive T112+idr48 is $22K, the M7cl-48 is just under $28k, the M7cl-48es with 3 stage boxes (48 + 24ch) is $36k. Street prices are highly varible, but the iLive can be found $17-18k, about the same as the M7cl-48. The M7cl-48es system will be more, probably $23-24k street, I'm guessing.
Here's a link to a UK company that sells pro audio, for entertainment purposes only... multiply prices by 1.57 to get approx. dollar equivalent.
http://www.theaudioworksuk.com/index.php/live-mixers-desks/digital-mixing-desks.html
-Tim T
I was asking specifically about the 48-channel rack and the T112, which it seems MAP on the pair is north of $20K, with street price on the M748 being $17500 or so. My numbers are probably off, but I was pretty surprised at the report that this config of the ILive is half the price of an M7. If I could get the T112 and the 48-channel mixrack for $10K, I'd own it tomorrow.
I think it depends on what side of the pond you are on :razz:
Over here, an M7 (analog) lists at about £23k, -ES version about £28k. iLive T112 w/ iDR48 is about £12k
Now your dealer price may vary, but there it is.
Incidentally, this is also true with Digico/Avid. In the UK, Digico is cheaper (by quite a bit). In the US, Avid is cheaper...
EDIT: Matt Sales is quick on the old forums!
Brad -
Thanks for the numbers supporting that in the US while the iLive option is definitely less expensive even if one does a closer 'apples-to-apples' comparison to the Yamaha M7CL-48ES system using three iDR-16 in place of a single iDR-48, it is not as big a difference as the 11k versus 25k price ratio Matt had noted for an T-112 and iDR-48 versus an M7CL-48.
Chris, it is interesting how some brands seem to differ so much in either direction while others exhibit very little difference.
Brad, I don't get how 3 iDR16 would be a useful system for a comparison. That would be 3 desk-brains, 2 more than the M7CL-ES would have. Definitely not apples to apples.
Apples to apples might be:
M7CL-ES plus 3 SB168-ES
vs.
iLive T112 plus iDR48
So both systems would have one brain, 48 ins and 24 outs on stage, knobs and faders at FOH...
I have not done the numbers on this but I'm fairly confident that there is no market where the M7CL configuration is within a 20% margin to the iLive configuration.
vs.
Going to 3 iDR16 lets you use CAT5 for your drop snakes, although the better way to accomplish this is probably with an iDR-16 and 2 xDR-16 units. MSRP on this combination looks to be ~$1250 or 12.5% over the iDR-48 (at least in the US)
Agreed,
Its all a case of exchange rates and manufacturing.
Allen & Heath and Digico are both British companies. Allen & heath split their manufacturing between the UK and china, Digico design and manufacture in the UK. This means that we benefit from lower prices with no currency exchanging or import duties.
Yamaha do everything in Japan, and one of the reasons they have become so much more expensive than they were is because our exchange rates against the Yen and import duties jack up the price. Not to mention their component costs going up.
1 iDR16, 2 xDR16 as expanders plus 2 ACE cards would get you three 16 channel stageboxes, if you want to have them. Staying in the apples to apples scheme, how many are using the ES units as drop snakes?
So the ACE cards add up to the price.
More common would be a iDR32 or 48 plus one xDR16 combination.
I actually use copper for the drop snakes, don't trust the stage wizards to leave a CAT5 snake unharmed through the gigs. Maybe that's just me, I'd like to have some redundancy on stage.
The point was simply comparing not just 48 total inputs but rather comparing systems with three 16x8 I/O devices, which could be a factor in some applications. Also keep in mind that the potential cabling issues you noted would probably not apply to every application such as most installed or house systems.
I read you, Brad.
Applications indeed vary.
So, to have 3 stageboxes:
1 iDR16 + 1 ACE card
2 xDR16
What is the pricing of this vs. the Yamaha ES configuration in the US?
