Here are some of the obvious ones.I read the press release, and it's still not clear to me what has changed!? Still seems to be lacking moving faders?
They won't be adding motorized faders anytime soon. From what I heard from a rep I talk to, the cost of adding it, at the particular quality they wanted, ended up adding anywhere from 500 to 1000 dollars to the finished product.
So what if that means a lot of us would actually buy it! Or maybe not, that ship might have sailed, docked and sailed again.
Motorized faders on a product where everything is patched 1:1 per fader is a bit overkill. The argument is that without layers or some other need for faders to recall, there isn't a reason to have them on the console. They've also built in a cool feature called "fader recall." This is useful because when you recall a scene, the faders aren't physically moved, but their software positions are the same as when you stored the file. By turning on the fader recall feature, the led meters will show you how far above or below the actual software level the physical faders are placed.
Even though motorized faders would be awesome, there just isn't a need for them in the particular product and it's form factor.
I did a gig and because of intermittent iPad connection was lost in the sauce as there was no quick way to visually verify where any fader... Including the Master!!... Was set! Really not fun at all. And the lack of dedicated FX return faders is just a PITA.
Did you not utilize the "Fader Locate" feature?
I agree with everything you all have said. The biggest thing to keep in mind about the PreSonus SL consoles is that they are more of an analog board than anything. Think in terms of analog, and you'll be better off.
I don't need a 12 pound hammer when 3 pounds will do.
Sure, some of us are just explaining why we are not buying this product.I think it's time to remind everyone that criticizing a console because it doesn't have the feature set that YOU need is specious.
You need to tell their marketing people, and the guy that came up with the name.The SLive, while it can be used for some live sound situations, was designed for and released as an integrated recording/DAW system and is great for that.
There are a lot of other things that I like about the board and being in the end of the business where motorized faders aren't really necessary it makes me no never-mind that they aren't included.
