Re: Subs @ 30 for an install
But wasn't it
XS-21 Chimera 21" Bass Horn - Ramsdell Pro Audio Products that was referenced, which is a different product (although it may use the same driver)?
I'd definitely like to see more information such as whether the sensitivity, response and maximum output are based on whole space or half space conditions and a response curve that might also help determine whether the stated sensitivity and output are the overall output over some bandwidth, the peak over some bandwidth, the minimum over some bandwidth or what. Since the stated 140dB maximum output, assumed to be at 1m since that is not noted, does not seem to relate directly to the 108dB sensitivity and the 1,000W/2,000W/4,000W power rating it would also be nice to know how it was derived.
One of the "interesting" things of note in the specs is the sensitivity number stating the use of pink noise.
It also says 1watt. How is the 1 watt calculated/measured? Since pink noise has a crest factor (6-8-10dB are very common). So assuming a 2.83V at 8 ohms=1 watt, what is the voltage actually used is it some sort of average or a peak or the continuous etc? What were the settings on the SPL meter-slow? fast? peak? etc You can get very different numbers based on the speed of the meter.
I have started doing a "comparison" between different loudspeakers (by different manufacturers) using a common method to all.
My standard voltmeter is the old analog HP 400e. When viewing normal pink noise on this meter-the scale jumps all over the place. On a 3 volt scale-it bounces between below 2.5 volts and off scale. You can "kinda" average the readings-but it does vary. an SPL meter measuring pink noise will also jump all over the place-remember the continuous to peak ratio.
So I have started using the TEF sync pink noise. This has a different "sound" but is still 6dB crest factor-but allows the volt meter to be MUCH more steady-only varying 1-2 tenths of a volt. It also make the SPL meter stay rock solid on a slow response measurement.
Anyway-back to what I have found. The comparison is very simple. Have the TEF supply noise-and the volt meter read 2.83V (or as close as I can get it). Put the loudspeaker on the floor and the SPL meter on the floor 1 M away on unweighted response and slow. Read the number.
Yes there can be all kinds of variations-depending on a lot of variables-but it does give a good "reference" between different cabinets.
What I have found by using this method is that pretty much across the board-the SPL reading on the calibrated meter (The same calibrator is used for the SPL meter as well as the swept sine measurement of the TEF) is 2-3dB higher than the published sensitivity of the loudspeakers.
Now granted-there are all different kinds of ways to "measure with a standard input of pink noise".
All I am saying is that the same loudspeaker can have different numbers assigned to it-depending on the test procedure.
Here is what
