Re: Suggest a mic mount for this grand piano
I have a response from my friend:
So, I guess that design isn't working out as good as I thought. If anyone has thoughts on how to improve on it, I welcome them. If I knew of a shorter boom/clip, that would probably solve it.
Grant
The Earthworks system was my inspiration to try a shower curtain rod and 2 of these. My piano playing buddy likes it.
Grant
How do you keep the rod from rotating owing to the off-center weight of the mics?
Quote: said:I immediately noticed the weight torque issue, so I actually just mounted the mic close to the high register with a piece of foam that the mic rests on. I used a dynamic for live rehearsal usage. I would imagine a small diaphragm mic would work just the same, but there's really no way around the torque issue with the current design.
The only other solution is to use ''lavalier'' condenser type of a pod, like what we use for choir mics, and rig a way to mount those plastic holder thingy's on the rod. Then there wouldn't be enough weight to torque
maybe...
Grant
