Re: Tell me about waves
Hello Harry, I may be able to correct a few little errors in your post since I am a frequent Digico +Soundgrid user, and intermitently Venue as well:
Digico has the control computer and the SG hardware built in as far as I can tell. The server is all you need with them.
This is correct, but there is no SG hardware built in. The processing is done by the motherboard and SPFGA chips on the desk, and in all SD series consoles you can add a Waves card (each console has a different one) wich the console will see as additional io.
I believe there is a card for A&H and Soundcraft, and there is a card for Digidesign venue too. I have no idea what the channel counts are.
A&H, Soundcraft, Presonus, Mackie, Behringer and Midas all can interface with a MR native/SG via either propietary cards or the built in firewire or usb ports. However, there is no Soundgrid or waves card for Venue consoles. V9.1 Plugins will work with those, but not the very new ones (vitamin, abbey road, etc).
There is an MGB and MGO which are madi to SG convertor boxes that run about $2000. They handle 2 madi universes for a total of 128 channels each way, but I think you are limited to 64 for multirack. You can probably run a second server to get another 64 though and on the same network too.
I believe there is no limit to the number of racks you can set up in your session. The limit is given by the hardware you are processing them, ie computer in MR native or wich server you use in MR soundgrid. If you add another server to the network, it will become redundant server. You cannot allocate different plugins on different servers. You can, however, route differnt inputs on both madi streams to Multirack or recording/playback computers. This is very flexible.
There are also ways to run all of this redundantly but I'm not sure how all that is implemented. I do know you need a sep license for the backup, so that would be 2 licenses for every SG plugin you use. This seems well suited for the SD7 which also has 2 mix engines for redundancy. In fact they have a plugin bundle called SD7 Proshow which is 2 licenses for every plugin and it's nearly twice the price of the Proshow bundle.
Redundancy on almost every console is very easy implemented and you don't need double licenses. You simply add another server to the network and give it another ID and the system will reconize it as redundant. On the SD7 you do need double servers and double licenses, although I'm not sure that you do have to pay twice. The few times I've used the SD7 with waves I had only one engine running, thus only one server/license.
For example, I use on tour a SD8 with double Impact servers and have 23 racks and about 40 plugins on a 56 channel input list, and the performance meter on the servers gets only to 60%.
Hope this helps...
