Re: Uli Behringer of The Music Group Q&A
This is an important topic and please allow me to offer some clarifications.
I'm not sure it is accurate to say that there is a difference in philosophy between MIDAS and BEHRINGER with respect to how each brand looks at digital audio. In fact, both brands are committed to the support of complete digital product eco-systems that meet the needs of their customers. This includes standards-based networking designed around the the specific needs of live sound; where low latency and clock stability are critically important performance parameters.
Where the brands differ is in the type of solutions they offer to their customers. MIDAS is a brand that is respected for decades of stellar sonic performance and rock-solid operational stability in the most demanding applications. MIDAS products are used in extremely high-profile events with sometimes hundreds of channels routed through several consoles. In this environment the unique attributes of 96 kHz sample rate, total redundancy with two independent network rings and up to three power supplies and sophisticated signal routing are mandatory.
The X32 uses the very same AES50 network topology as is found on MIDAS Digital consoles. This network is designed from the ground-up to offer the very lowest possible latency and highest stability because it is designed to carry live audio streams; not packet data. On the X32 the network is used not only to connect S16 stage boxes but also to link several consoles together, allowing them to share inputs. In this way one X32 can mix front of house while another mixes monitors for example.
The way in which channels are routed is determined by the intended application for the product. In the case of the X32 we opted for a scheme that makes sense for the way that buyers of this console will be using it. The result is a channel assignment method that allows a user to set up and operate the console quickly, efficiently and with enough flexibility to mix mains, monitors, recording and even a broadcast feed from one set of inputs.
Warm regards,
Uli
Warm regards,
Uli
