Re: Upgrading our PA System - 12s or 15s, and are subs necessary?
My 2 cents - I would say that the 15" tops in the same model line do not go much lower than the 12" model from any manufacture. There are some dual 15 inch designs out there.
The cabinet volume is not large enough to port too low. If it is Acoustic or voice only reinforcement they will do fine. Other than that having a real sub helps. Less stress, lets you use a 12" box for a smaller truck pack, lighter to move.... 12, 15, 18's in a much larger box can go much lower, but are not as easy to balance on a stick.
