Re: X32 Rack
Even if I cannot see a good reason why you want to do that and you cannot fulfill your needs with the Pan of the Stereo master, I see only one way to do that, even if it is a waste of Matrix Channels:
1. Create two stereo matrixes using the Link function in the home->config of the selected matrix. Now you maybe have linke Matrix 1 and 2 as well as matrix 3 and 4 to two stereo pairs.
2. On the Main Send page send with the same level the main signal to both stereo matrix pairs, probably post fade to allow you to use the main fader as well as the matrix faders.
3. send the output of matrix 1 to the left side amplifier and the output of matrix 4 to the right side applifier.
now you can control the level of left and right using the faders for matrix 1/2 and 3/4.
keep in mind that the matrixes pairs must be linked otherwise a matrix will get the mono sum of the stereo main signal.
you see it is possible but not a really senseless solution. I would suggest to use the pan to calibrate left and right level.
