Re: Yes, it's cliche, yes it's overdiscussed, but yes, I need new subs.
The Growlers aren't a particularly efficient cabinet - about the same as an SRX718S but can take quite a bit more power without distorting. I've concluded that folks don't really want clean hifi bass such as the Growlers generate - your ears really don't pick it up well. It's the harmonics that we perceive as strong bass, not the fundamentals. When driven past xmax subs generate quite a bit of that which I believe is why many folks are always saying that a certain sub doesn't "come alive" until powered to a certain level. None of my subs go much below 50Hz but I use a Waves "MaxxBass" unit to generate those harmonics that make them sound like they go down to 20Hz - unless you get close enough to notice there's quite a bit less air movement than expected up close you really can't tell I'm "faking" it . It's particularly effective on conventional horn subs that get all flabby if you feed them anything below their cutoff.Also, FWIW- I've used the JTR stuff and have not been impressed.
