I'm researching subs with high output for a specific application where we are limited by the numbers of cabinets(12). I did some reading around the interwebs and there are two units units that place themselves at the top, Danley TH812 and McCauley M421.
Now, if we for a minute look away from all the usual considerations (price, amp cost, processing demand, truck space, weight, sound quality etc.) which one of these two produce the highest level of output if you put them out in a open field with the manufacturers recommended amp and processing?
Are there any rental houses in Europe that stock 12 of either of these? I could rent them from the US, but shipping would probably be cheaper from Europe.
And are there any other subs I should consider with that kind of output?
I've used 12 EAW BH760 once, that was impressive. I see a lot of them used, but I believe that they are a bit short on output for this application.
