Re: Marc Lopez of Yamaha Commercial Audio Q&A
No need to be concerned. Set the gain lower than you would on your analog board to give yourself headroom for when the singer "lays into it". You have separate digital gains on each channel to allow you to trim the level as you wish, so you can have different "gain structures" on each channel even when sharing the same head amp.I was under the impression that with the RIO input module you are sharing the same head amp (you have pointed this out above) so a virtual patch into two channels gives me separate EQ, DYN, etc... but not a separate gain stage. This is what concerns me.
