Peter Morris, how does the RCF MB12N351 compare to the B&C 12NDL76 in the PM90?
At a guess I'd suspect the RCF would do a little better up near the crossover to the BMS, whereas the B&C might have better displacement limited power handling due to higher xmax (I'm not sure if this would be any benefit at 100Hz with a HPF?).
I'd eventually like to upgrade my tops to PM90's. My system is used mostly for DJ orientated gigs, which seem to suit having a little extra in the kick bin frequencies, for better integration with the usually somewhat louder subs. The cost savings of the B&C are tempting, although I'd be reluctant to make significant performance compromises for the sake of cost either.
