PM 60 & 90 settings and alternative drivers.
If I recall correctly, the MB12N405 would work nicely.
Main disadvantage would be it immense weight for a neo 12" driver (which defeats the original's purpose of the design).
Plans should be available in the main two topics about the PM60/90.
The MB12N405 will work but the response will need more EQ than the 351 to get it flat. If you can't find the plans send me a PM and I will send them to you - Regards Peter
Does anyone have eq settings for the DCX464 on the XT1464 horn? thanks!!
Yes I have some DCX 464's ... I have tried them in a slightly different box and horn. Impressions so far - better than the BMS4594 and as good as the 4594HE but different.. The 464 seems to have very clear mids and possibly more output capability, but I like the VHF better on the 4594HE. FWIW I think the wave front exit angles and SPL across the throat of the 464 are better than the 4594 so you get slight better coverage from your horn ... just a guess at the moment.
Not sure, still work in progress... but getting the 464 to sound the best you need to address the mid range driver peak at about 5.3 KHz, even though its out of band and cross it over around the 3 - 3.2Khz as recommended by B&C.
...and yes it will work well the 12NDL76 .... just need to check it will fit in the box with the 60 degree horn ...planning to check this all out soon when I have some spare time.
IIR settings for the PM90 with B&C 12NDL768 Ohms, B&C DCX464 16Ohms using the B&C FB464-16 Crossover & RCF HF950.
Mid-Low:
120Hz Butterworth 24dB
600Hz Butterworth 24dB
160 Hz Q10.0 6dB Low Shelf
400 Hz Q3.0 -6.00dB Bell
Delay 2,331ms
Highs:
800Hz Butterworth 24dB
1450 Hz Q5.0 -2.00dB Bell
2500 Hz Q4.0 -4.00dB Bell
4700 Hz Q5.0 -3.00dB Bell
8000 Hz Q3.0 -3.00dB Bell
30 Hz Q1 Allpass (important!)
Edit: Sorry, for got the mention the crossover.
Edit2: Added the delay for low mids.
Mid-Low:
Highs:
Hello :)
Do you still use these settings or did you make any tweaks?
Thanks!
Hello :)
Thanks!
These are setttings used by friends, how frequently borrow the cabs. They did not tweak any further and are really happy. As stated many times before, only by going fully active and using FIR you will be able to get the max out of it. But still, with the above settings you will get very nice sound. Important: Don't forget the Allpass filter for the phase.
Edit: I added the delay in the above settings.
