Hmm... the internal AP only supports WEP "shared key" and Windows 8 and above only supports the more secure WEP "open system". So you can't connect from Windows 8 or 10. Good one Behringer x(~:dead::roll:8O~8-O~:shock::razz::thumbdown:
Prolly cheaper?I don't know what the engineers designing this thing were thinking when they selected a wireless networking module that does not support WPA2/CCMP in AP mode.
Actually according to Microsoft "open system" is harder to crack than "shared key" which is why they stopped supporting the latter.Yes, "open system" is less insecure than "shared key"
Just to be clear- no, I'm not worried and have a WEP "open system" guest network (internet only) set up at home for a few devices I own that can't do WAP. I just want to be able to connect to the X-Air wirelessly at home and possibly at venues not located in WiFi congested areas.but if you're in any way worried about that difference you really should not be using WEP at all anymore.
Well, just for kicks I wanted to explore its limitations. If there's a channel free for it to work on I don't see why it can't work?The internal ap is not usable for anything except for setup in the shop.
Just to explore a pet peeve of mine (AKA poor understanding of networking) I run my Mackie DL1608 with a 5GHz AP, no router needed 8)~~. Of course to make that work I have to run static IPs as I have no DHCP but the DL works better that way anyways. I haven't tried that with the X-Air yet but it supports static addresses so should work fine and even has a DHCP server if needed/wanted.For anything else you need a good router
[/FONT]Regarding the internal AP in X AIR mixers, we provide an affordable solution that works for a majority of our users.
