Re: Change routing without losing gain settings and 48V
Then a channels on X32 are routed to a S16, gain knob on X32 adjust the gain on S16.
Problem is then you want to MOVE your sets of 8 physical mic to other inputs and change the routing. You don't get gain values and 18V with you and have to adjust them again from X32.
You can do this routingtest internally on your X32 and have same results.
Would it not be possible to just use and adjust only the on board gain on the x32 and ignore the snake pres while using the snake? I don't have mine yet, and if this is going to be an issue, I might just stick with a regular snake, or use the monitor console as the point of input and cat 5 out to foh from there.... This issue should be addressed (behringer).
