re: X32 Discussion
Hi,
if you hook up the S-16 like this:
X32 AES50 output A---> S-16 No.1 AES50 A input-->S-16 No.1 AES50 B output-->S-16 No.2 AES50 A input and so on, there is nothing to care about. It sets up automatically. On the S-16 it self, you can choose, which outputs you want to have on the analog outs. Every S-16 can play out any Mixbus, you can choose in blocks of eight (f.e.1-8, 9-16). Default setting is Mixbus 1-8 out an the S-16. I don't have a S-16 here, so take this information with caution
Christian
On each S16, how does one select which channels it will be i.e. the first one will need to be 1-16, the next one will need to be 17 - 32 etc. Presumably a configuration option in its menu? What happens if you plug in an S16 set to the same channels as one that's already connected? Will it tell you there's a conflict? Just ignore it?
Thanks!
Hi,
Christian
