re: X32 Discussion
If you are only using 24 channels, you could of course route back to 25-32. or use 25-32 as inputs and route back to 17-24.
Another way, if you don't need inserts on all of the channels, is to route inserts via aux to card, but that would limit you to four external inserts. Yet another way would be to mix the channels that need processing to one or more subgroups and do the inserts there, same limitation in number of independent inserts, but you would have the opportunity to let the lead have his/her own processing and let the backing vocals share processing.
Or we could ask to have the insert routing extended to include the card (something I think would make sense for a lot of applications), but that won't help you now.
I'm using the desk for inputs 1-16 then 17-24 are sent out via firewire to my macbook pro running logic so I can use waves desser on vocals. So I'm using card input 17-24.
Using 24 channels of input from an analog snake. I get that it should be a digital trim when it comes back into the desk.. but what I'm asking is there there any way to adjust the preamp level besides switching back to desk input 17-24 then back to card input 17-24
My signal flow for channels 17-24 being.. snake>analog desk input>X32 firewire output to macbook pro>macbook pro output to X32
Does that make sense?
