If you're asking me you'll have to quote what you're referring to? I mentioned three amps .Did it have more power, or just more gain?
^ I assume a XTI4000 is bridged into each sub vs a NU6000 driving two ? That would account for the XTI having more power.
Thought I would provide some feedback of my experience with an INUKE 6000 DSP.
I run a small company specialising in live sound, we seem to do mostly rock.
I like many others have mixed feelings about behringers products, I have both good and bad experiences. Their analogue mixers I find to be unreliable, I have about 5 with misc faults whereas my soundcraft and Allen Heath have been A1. The Behringer amps, compressors and eq's I have are reliable. I will never buy another analogue mixer from Behringer.
I bought the Inuke due to it's great spec and price and weight. It is so good on paper thought I would try one.
I first tried into a pair of 2X18" 2KW Rms. subs. So 4 ohms per side stereo. Now I don't know how to test amps, the only tool I have is my ears. I found the amp to be louder than my peavey pv2600 and delivered powerful great sounding bass.
Then we used it on an install at a venue where it drives a pair of 2x15" subs which are rated at 1200W RMS each. (again stereo 4 ohm per side)
We have now done around a dozen shows and the amp has been fine so far. This amp runs cool no matter how hard you drive it. It is loud, it is getting the job done. Looks like a great buy to me.
I Would like to see an independant test of its claimed output power ( the RMS ones). If they are correct or even close then this amp looks to be a bargain.
Update:
This amp failed after approx. 25 shows and is being sent back to Thomann.
Really disappointed
Update:
Really disappointed
Update:
Really disappointed
We think the amp failed on power up.
It had been used the night before and it was good at the end of the show. It is an install so it was not moved.
When we switched the amps on Saturday it switched itself off and the display didn't light up at all.
This amp is had proved itself from a power output point of view. But of course we need is reliability.
Have been contacted by Pat and the Uk service centre and they have arranged collection of the amp.
Hoping for a positive outcome as I already bought three more of these.
What I would say is Behringer seem to be adopting a pro active approach to service.
If this continues it is very impressive.
We loved the weight, sound and price of these amps we really hope the failure is just bad luck and the design is ok.
I see it's been a few weeks now. How goes the warranty experience so far? Problem resolved? Amp back in service? Amp repaired or replaced? Please update us.
The service I received was second to none. Thanks to Pat and all in Behringer who were involved.
Yes, amp is repaired and back in service.
I received a level of service and support that I have not experienced before. I was contacted by Pat at behringer who had the unit collected and fixed and then returned to us. All at their cost.
The report said 3 components had failed, they were numbered beginning with d so I suspect diodes probably in the Psu.
The other inuke 6000 dsp we have in use is up to 30ish shows with no issues sofar, I really want this amp to work as it is fantastic. Above all else though we need reliability. If the amps are good for the next 3 months I will order two more as nothing can touch them for price/performance.
We have two more inuke 6000's which will go into service soon.
How interesting the way things can change - who would have thought..........
Popularity must be increasing too, I see that they are getting thin in supply, similar to Peavey IPRs.
So far the only neg I've read about the Nu series is the fan noise being described on par with a hair dryer.
What has been your (or anyone's) experience with fan noise?
If you would have said that several years ago, nobody would have believed you. I would have said "Inconceivable!"
I love how JR puts it: This ain't your father's Behringer. Impressed yet again, and slowly building a good track record for service.
Update.
In total we bought 2 DSP nu6000 and 2 non DSP units, so 4 in total.
Last night we had the third failure this time a non DSP unit, the amps are racked in an install and the old peavey and QSC units in the rack with them have never missed a beat.
I thought this would be quite an easy life for the amps. They appear to fail in exactly the same way, the first one was Psu failure and the last two appear to be the same although they have not been repaired yet the symptoms are the same, I am wondering if there is a design problem with the Psu.
I am very disappointed with these amps.
Update.
