Fader caps
So, what I really want to know is where do I get the slick fader caps that the new "desktop wallpaper" photos on the Behringer.com site show.
These --> http://www.behringer.com/news/files/2012/10/x32_wallpaper_landscape_1024_x_768.jpg
They look like the fader caps on my SC-48. Way nicer than the almost flat-topped, slippery, and in my opinion cheap looking, caps that came stock on my X32.
Anyone know where to find them?
Re: Fader caps
They look like the caps that were on the desk I use as it came out the box...
Sending USB audio to DAW
I realize that I can playback recorded audio from the usb drive but how do I get that into my DAW (without physically moving the usb stick to my PC)?
The faders for Aux 7 - 8 control the level.
I've tried the USb Config to no avail.
Thanks in advance for any help.
Re: XControl Full Screen
Walter,
how do you get your Xcontrol to display full-screen? Do you drop the display resolution or is there a full-screen option somewhere I am missing?
Cheers,
Ryan.
His screen is at the resolution of the software basically. I hope they add the capability to change the window size in the future.
Re: Sending USB audio to DAW
Re-assign the USB to inputs 1-32 or aux 1-6 and then make sure those channels are routing to the card via the routing/card out tab.
You can route the USB L/R to a pair of the 1-32 inputs, or to Aux 1-6, and then make sure that in the routing/card out tab you route the appropriate channel to the card.
You are wrong about internally routing the USB playback to a pair of channel inputs.
That was one of the 1st things I've tried when i got the x32, then realized that only the 32 physical XLR inputs can be sent to the DAW.
Not sure about the option to route Aux 1-6 though. I would think that it would take the signal coming in from the physical 6 TRS inputs,
so... Yeah... no way to do it with patching internally, just physical cables from outputs to inputs (as far as i know).
Re: Internal crossover function in new update
Where did you buy them? I've been waiting for Sweetwater to get mine in. I have two S16s that I've been using for a couple of weeks and have to give them up soon. It's going to be hard to go back to an analog snake. You're gonna love these things!
You can buy them from me. I have a access to 1505 in a Behringer warehouse 10 minutes from my shop.
Broadway Music Inc
8121 Taft St
Merrillville IN 46410
219-712-7086
Brian Wynn
Broadway Music Inc
8121 Taft St
219-712-7086
Brian Wynn
That's just not fair , I was told by my dealer I wouldn't be seeing any in Canada till jan... Distributor fail...
Brian, can you pm me pricing please, shipping to 13669, ny
Sp
Headphone jacks
The other day I had a pair of headphones plugged in and they were working fine using the jacks on the end caps. I plugged a second set of headphones into the jack on the other side and when I did that, the volume was significantly reduced in the headphones to about half and I lost the stereo mix and only one side of each headphone had audio coming through.
Has anyone else had this problem or have any recommendations on how to fix this? Perhaps this is just normal?
thanks in advance!
karl
