Re: STP vs. UTP
Dear Dan,
don't get me wrong, I am not inclined persuading you of anything....
Hi Jan,
Please DO try to persuade me, I am open to learning what is going on as opposed to what I THINK might be going on, and I appreciate your efforts to try to enlighten me and the community.
Also, congrats to you, Uli, and the entire Music Group on the 25th year celebrations! That is worth celebrating, and I hope the festivities are enjoyable and portend well for the next 25 years.
However, back to the problem at hand, which is why one set of consoles and stage boxes that use a variety of AES50-compliant protocol over UTP is immune to ESD, and another which uses essentially the same thing is not.
You mentioned earler
...From basic electric laws, you may consider that the impact of any given electric charge will be largely depending on the device's mass and its grounding impedance...
and then say
...Off the top of my head, I suppose there will be an avalanche of charges distrubing several processes at the same time in a pretty uncontrolled manner, whenever an ESD actually manages to get in and hit the circuitry. This might affect both sync pairs at the same time, so that the sync redundancy does not even help in this issue. I am afraid it will hardly be possible to react on an event like this by software measures at all, and it is probably better to try to prevent it happening in the first place, e.g. by using good chassis grounding and screened cables...
(emphasis added)
Despite your stated personal preference to use screened cable, it is quite clearly Official Midas Policy, based on the apparent fact that UTP is the only cable sold by Midas with the consoles, as well as the specific statements of two separate Midas Customer Service employees that UTP cable works fine with all Midas consoles and there is no need for screened cable.
Since the mass of the smallest Midas console is roughly the same as the X32, it seems safe to assume that the problem with the X32 requiring STP is not lack of mass, which then leaves grounding impedance and good chassis grounding as the culprit. You didn't mention proper shielding of internal components, so I assume that is not a factor.
Your comment about grounding impedance reminds me of the Pin 1 Problem that Neil Muncy made us aware of twenty-ish years ago, in which he pretty conclusively showed that grounding pin 1 of your xlr's to the console (or other analog device) through circuit board traces had enough of an impedance at high induced voltages to inhibit the path to ground and cause various hums and buzzes, whereas using a not-necessarily-huge wire or a VERY LARGE circuit board trace allows swift zeroing out of that induced voltage, and no hums or buzz.
That was a problem which was trivial to solve in the design and manufacturing stages, but much more complex when trying to solve it for a piece of existing gear.
Are we looking at something similar here?
And is the problem in the S16 stagebox and not the console itself? The console's analog XLR's seem to be fine with routing ESD to ground.
One of the things I learned from my Audio Over Ethernet Cable workshop (which John DiNicola attended) was that something like 98% of all RJ45 chassis connectors have fairly high quality transformers built in for each of the four pairs in the Ethernet cable, and that the volume in which those are made makes it both not expensive to do so and easy to get relatively high quality in the little transformers.
Does the stage box or console have some kind of deficiency in this area? I'm pretty sure that the console end has transformers, to the best of my limited ability to measure such a thing; how about on the S16 end?
I don't understand how shielded cable would solve lack of or insufficient transformers, so maybe the transformer thing is a red herring?
You can see, I hope, that I'm trying to understand what's going on, and would be fully happy if the X32 family could be made to more closely behave like the Midas in regard to UTP.
Thank you and other Music Group employees for continuing to try to enlighten us.
Best wishes,
Dan
