re: X32 Discussion
Sure, you can do virtual soundcheck with up to 32 channels. No problem. The USB recorder is only capable of doing a 2track recording. You can use the USB on the build in recording card, but you imho need a DAW software (like Presonus StudioOne Free) for record and playback to do so. I don't think, that the possebility to track right to an USB hardware/stick without any recording software is given. I know it was in discussion in the early days of the X32, but I can check back with the Behringer boys
Presonus has the ability to recording channels, directly after mic preamp, to PC. Switch mixingmode and play all channels from PC
to each input channel and adjust all channelsettings while listening to whole mix. It's like mixing without a band.
Is it possible to do this for 32 channels on a X32?
Can You do it for 16 channels using a hard drive connected to USB on the card.
