Re: 60 Degree DIY Mid Hi
What I’m going to do is add 3mm to the 43.31 and 76mm. I’m using 16mm ply and I’m making it 386mm wide (external). I am planning on eliminating the 10mm space and routing a grove to allow for 10mm of cone travel.
Hi Peter, I took your adjustments and went to 47mm and 79mm... this gives a spot-on slope on 9 degrees for the baffle board, and for easier old school calculations
Pieces are cut and under glue , yea. (I'm using 18mm BB ply for both horn and 12" baffle boards, as well as MF horn walls. Everything else is 15mm ply.)
So outside dimensions are 380w by 430d by 932h, as I've tried to hold the MF horn dimensions right to 90x50 plan.
Those original plans for the 90x50 are laying out great for both horns...and with removable baffles, double yea.
The HF950 works of course works great as per plans (thank you too, Don) .... the XT1460 baffle board is comprised of a two thickness bafffle board...one spacer the same 18mm thickness as the HT950 baffle, and then 15mm pieces on top of that spacer cut to fit for the XT1464.
Still, a few questions please
Is there any reason other than creating clearance between the BMS 4594's terminals and the 12" RCF drivers, to recess the the 12" in the baffle boards?
IOW, does the volume between the driver and baffle board matter?
I've cut 12mm spacers, but have also tooled up to recess the RCF's into the baffle boards per your suggested tiering....doesn't matter construction-wise which way I go...... I think clearance will work either way although that's clearly more certain with recessing ...just want to optimize for sound quality
And what did you find center of gravity, front to back? IOW, pole mount position.
Any reason not to put handles in the center of the box vertically? I'm thinking the handle holes in the center will help making sure wires are OK given the tight clearances.
THANKS
No reason - its just to create more space. The volume between the driver is a little less but I ran a sim and the effect is very minimal. As you said it will work either way.
The centre of gravity is towards the back of the box. I just found the balance point and mounted the pole-mount accordingly.
I positioned the handles towards the bottom to make it easier to walk with the box and lift it onto a speaker stand.
I was to try and stop the bottom of the box from hitting your legs as you walked and reduce the additional lift need to place it on a stand .... not sure I got it 100% correct.
