- True channel insert patch to and from Card slot I/O for easier DAW/ plugin integration
- capability to fully remote controll X32, X32 Rack, and X32 core from an X32 console.
allowing to use X32core for example as individual Monitor mixer (each X32Core feeding only One monitor output, but having own Fx and own full processing for all channels. (Kind of SAC monitor mixing experience, but on real low latency hardware)
- also incorporating the possibility to send pre/post EQ, and/or Dynamics and/or fader all channels on the AES50 in order tho chose the source for the individual monitor mixers (X32Core units) (user could use monitor mixer #1 EQ settings on all of the monitors, avoiding the need of setting up the same EQs and dynamics etc on all other Monitor mixers)
just think about a cheap 40 input FOH and Monitor mixer system with as many stereo i dividual monitor mixes (with their own EQ, dynamics, FX and plugins) as you want (depending on the number of X32core units used in the system)
cheers,
Tamas
cheers,
Tamas
