Re: X32 Discussion
This would be a perfect job for the personal monitor system!
16 channels of submix into two channels going to the recorder...
That might be a winner of an idea! We are already going to implement P16-M's for the instrumentalists in the Praise Band! They have through functionality, right?
Installing X32 USB ASIO Driver
I am having a problem installing the X32 USB ASIO Driver on my laptop. The install almost completes, and then a window comes up asking me to "Disconnect and reconnect your devices and turn them on." I do this but nothing happens, after a while the message comes up again. The progress bar never completes.
The laptop is Windows 7 Home Premium 32-bit. I wonder if anyone else has had a problem and can assist me.
I have searched for help on the web on this issue but haven't found anything.
Mick Berg.
Re: Installing X32 USB ASIO Driver
I had the exact same issue, Mick. I believe the installer is looking for an active board on the USB chain. Did you happen to select USB on the X32's expansion board page? I didn't realize it, but the X32 does not automatically switch between Firewire and USB; you have to specifically select one or the other. Once I switched, it found my board and finished the install.
Mick Berg.
If your experience mirrors mine, odds are that you've plugged into the "control" vs the "audio" USB jack.
Look at the back of your console. Is there an ethernet (RJ45) jack next to where you're plugged in? If so, unplug from the board and plug in next to the Firewire jack. Works wonders.
Re: X32 Discussion
Jared, We'd like to do it live. We are recording the service right now on CD and on DVD, along with our video mixer output, of course. We are not recording the video separately, and doing so would add quite a few extra steps to the work flow (including having to separately record both the audio and the video, and then re-sync audio and video, and accounting for any drift.
So, it's not exactly like a studio recording mix, we just want a separate mix for the DVD and CD live recording. The FOH mix just doesn't sound right on the recording (no acoustic additions from piano, acoustic guitar, vocals, etc.). The "recording tech" would just make it sound good to his ears as it's being recorded.
Regards,
Gayle
There was something said quite early on about giving limited control to secondary remotes, limiting access to sends for particular buses and maybe the full access to the particular bus/pair of buses, but nothing seem to have been implemented as far as I can tell. One possible option would be to create a custom layout for TouchOSC, where you could give a person with an iPad full contol of a fader set of bus sends, the bus eq and maybe an effect. It wouldn't be too hard to do.
Steve.......Duh, jeez, how dumb can you get? I'm using the card, maybe I should plug into the card...................:blush:
Mitch.......I got that bit right at least!
Thanks to you both,
Mick Berg.
Thanks to you both,
Mick Berg.
No offence mick, but You might want to exhaust ALL your possible options before posting.
With all your embarrassed emoticons, you're starting to look like you have high blood pressure
:p
With all your embarrassed emoticons, you're starting to look like you have high blood pressure.
:p
Yes, sorry, this time I will admit that I didn't spend enough time looking for possible causes. But often one can't see the wood for the trees.
Mick.
Yes - because just like speaking louder to people who don't speak the same language you do improves their comprehension of what you are trying to communicate, staring at a problem for an infinite amount of time will always solve it :p
:p
That's a bit harsh and not very welcoming. How about not assuming everyone has decades of experience and that things that are obvious to you are obvious to everyone else?
How's this for a request - if you think a question is dumb, obvious or just not "worth it" stifle that desire to chime in and let it go. I've never understood this about forums - people who feel compelled to point out questions are silly, inane or can be solved by "just searching for it". Thanks for the blinding flash of the obvious!
So to Mick or anyone else who might be reading this thread and might be put off by responses like Shane's - please just ignore them. If you have a question and you feel it should be embarrassingly simple but just aren't getting it - ask it anyway! There is no such thing as a stupid question. There might be annoying questions if you are a serial asker of things that might be found in the manual - and you might get ignored on the 10th such question - but even both of Mick's questions really aren't that dumb because when you first start out neither of them are explicitly spelled out in the manual. That may sound silly to the "seasoned pros", but remember with the price point of this desk there are going to be lots of casual and non-pro users. For many this may be their first digital desk. And while the USB slots are "clearly labeled" - if the labels dont' have meaning since you are new to a TON of terminology and trying to absorb it all, that "clear label" may not be all that clear.
Not that I'm speaking from personal experience or anything either :blush: And you probably experienced the same thing when you were first learning - you just don't remember.
If a question just rubs you the wrong way or you think it's obvious and if you don't feel compelled to answer or provide otherwise constructive commentary, please just ignore it. The question will take care of itself - guarnateed!
Consider that these forums are a COMMUNITY of people, not a 'living wiki' that simply awaits questions and dispenses answers.... and just like in your own physical neighborhood, there are a variety of people, some of whom are nicer or more fun to be neighbors with than some of the others. My advice, if you don't like an answer, is to move on to a reply that is less emotionally challenging.
Well put Eric! I feel Tim's reply to your post shows there are 2 kinds of people in this world when it comes to learning. People like me who get frustrated after a while of trying to figure out something, and want some help, and others who want to figure it out for themselves and will stick to trying to figure things out, no matter how ling it takes. Not making a judgement here. In fact a large part of me admires someone who has the will to figure it out for themselves.
I feel if I am struggling with understanding a concept or can't figure out a technical problem, why not ask someone who has a much better knowledge of the subject? Why spend hours or days struggling with something and all the frustration that can bring if someone else out there knows the answer and is happy to help out? I admit, I'm a wimp sometimes.:blush: And it can even be more frustrating if it isn't covered in the manual.:evil:
I do believe no one knows everything about a particular subject, and even the most experienced of the bunch can sometimes learn something from somebody who is just starting out. Having been a teacher the last 30 years, I still learn things from my students. I think every person looks at things from different perspectives, and my students have made observations about things that I never would have thought or considered, so I am learning from them as well. I too believe there is no such thing as a stupid question, and a lot of times I learn from my student's questions.
As I have just recently considered getting a new mixer, I have spent the last 2 weeks researching digital mixers. Thanks to my Luddite ways, I am now trying to make up for lost time and catch up to the 21st century. Maybe it is just my age, but I'm finding learning about digital boards is more challenging than I thought it would be. Especially when it comes to routing and all the cool possibilities that are now open.
In Tim's reply to your post, I feel he has a valid point. Tim, if I hear what you are saying, this is a community of people and because of that, there are lots of varying opinions and expectations everybody has about this forum. That is what makes the world go 'round. Perhaps we all have to ignore certain posts and admit that just about any post may have the potential to irk somebody who may post a reply about their level of "ikedness", but in the end hopefully somebody will respond with an answer, and bless that person willing to help out and take the time to reply!:D~:-D~:grin:
Best regards,
Bill
Recording effects into a DAW
I can hear the X32 effects added to my guitar sound and I can record the guitar itself from the X32 into Ableton Live but the effects are not being recorded.
I know it must be something simple but can't seem to manage it.
Re: Recording effects into a DAW
If you want to record the processed signal, you need to route the signal with effects via a bus to an output, and record the output.
I have to side with Shane and Tim, no offense to Mick obviously (who oddly enough seems to be the one person who isn't offended by this). Working in support at various points in my life, both IT and pro audio, I can't help but shake my head at the number of times I've walked into a situation that was easily solvable by a single button press or plugging a cable into the correct jack. It doesn't hurt to spend a few extra minutes investigating a problem before calling for help, in fact it's quite satisfying when you crack an issue on your own no matter how small that issue may be.
<snip>
It always amazes me that there are "VIPs" spending their "oh so valuable" time on forums, taking time to point out that others are responsible for wasting that "valuable" time that could have been so much better spent if the "VIPs" didn't have to waste it on what the "VIPs" consider to be drivel or whatever.
Can't we all just get along?
Just bought an iPad and I'm absolutely loving the XiControl!!! Can't wait to use it at a gig! The band will think I'm the cats ass!! Because I am!! The cats ass! :D~:-D~:grin:
