Re: How to set up external effects?
If customs does not fail me, I'll get my X32 and a S16 tomorrow...probably the first one in Vietnam. I still have two BOSS SX700 Studio effects which I dearly love and now (after all the wait and trouble to get the X32 appears to be over) I start to wonder, how is actually the best way to integrate them into the workflow of the X32. At least now I am not going to get close to use all 32 inputs, and outputs should be free as well. Any advise?
Greetings form Hanoi!
Connect to aux out and aux in, set level on SX700 to +4dB and you should be good to go.
Depending on how you are going to use the processor, use one or two auxes per unit.
Assuming you are using stereo input and output, totalling four sends and four returns, route Bus 9-12 to Aux out 1-4 (ROUTING-aux out). Aux returns makes sense to keep on the aux channels, you'll then have all the effect returns on the same page.
Use the sends for 9-12 the same way as you would with the effect sends 13-16.
Alternatively, you can use the inserts on the buses 9-12, and have the effect return coming back on those buses, you would then route the buses to mains, and not use any output for those buses. Last alternative is to insert on channels, still using aux out/in.
Re: Expansion Slot Idea
Or perhaps a bunch of us could pool our money to buy a console to do a tear down <snip>
I'd throw in $20. Would another 150 people do the same?
I wouldn't mind contributing $20 as such, but as a customer I feel a bit disloyal contributing to a reverse-engineering excercise that isn't even likely to produce a lot of useful information from my perspective. We sort of know that there are Cirrus Logic CS5368 input ADs and Analog Devices AD21273 DSPs (whatever that is) in there, and from some of the pictures on this forum, there is probably some more information to be gleaned, but as long as we don't know how the signal processing hardware is connected to the control layer (physical and software), there is little to be learned in terms of what possibilities for firmware and software changes really exist.
Someone that knows the design can tell us for instance what routing takes place in hardware and what is merely virtual in the software/firmware layer, what is the structure of the routing table and how the scenes are indexed. Details like that might be totally useless for most users, but give a clear indication of what can be easily implemented and what requires major firmware/software rework and what is impossible without hardware changes.
In short, I would brefer Behringer to tell us as much as they feel they can without giving away any real secrets (and since there are no real secrets that can be gleaned from a teardown, I don't see any reason why they can't give us a complete rundown of the hardware)
Re: Monitor out noise
Acknowledgement for the extraordinary console for the price the X32 is, and that it does many, many things remarkably well (as you point out) has nothing to do with the fact that my console has gone up to the service center and returned still with the noise in the headphones for which it went in. If you can spare an output to feed a headphone amp and then your headphones, congratulations for your ingenuity, you are truly a gifted one. I don't plan on carrying an extra headphone amp to make up for something as basic as headphone monitoring that can be had in a $40 analog console made by Behringer too.
You wrote: "Short version: You cannot fix this. Maybe the Behringer Service Center can, and maybe it can't."
By writing "..and maybe it can't" you seemed to know that maybe this is not a fixable problem, given what you wrote, I politely asked my question as you seemed to maybe have info I didn't, but forget that...
My apologies for inferring from the way your two sentences were worded, along with the surplus of question marks, that you were preparing to go on a rant if the answers to your polite questions were "yes".
You replied in a sub-thread about "Monitor out noise", and I assumed that's what you were talking about, not the headphone out noise. Those could be different things, and certainly are in regard to the connectors used. I was speaking specifically about the XLR'd Monitor Outs, and did not intend to imply that I'm hauling anything around to be used for headphones. That is a separate problem.
I also had no way to know that you sent your console to a Service Center to fix a specific headphone output noise problem, and that it came back unfixed. You have more knowledge than I about whether the problem can be fixed or not; so far, the answer seems to be "no".
You do add a data point to the discussion, though; you are now the first person to say that Behringer Service had an opportunity to fix that specific problem, but didn't. And as I wrote in my reply to you,
"Further, since I've been following this issue, I am not aware of anyone who has reported having this problem with their console subsequently reporting that the problem has been solved. I am not omnicient, though, and may have missed something."
That statement is still apparently true. Since writing it, I remembered that one infrequent poster wrote that his console didn't have the problem, but has not replied to my subsequent specific questions about how he knows that.
I allege that, based on the small sample I've personally seen and on reports in this thread, every console has the problem, but that some people are not bothered by it because of either their methods of working or limitations in their hearing*. I will be happy to be contradicted, but will want specific answers to how someone feels they can prove the absence of a problem. FFT traces will work, RTA not so much.
Further, I will happily state that if headphone noise at max volume is the worst problem this console has, I am not at all bothered or concerned by it. Life is sometimes a bitch.
Fake edit: If the workaround on the monitor out (putting it on any of the other 16 analog outs) didn't exist, I would be very, very exercised about this, because that would prohibit use as a monitor console. On headphones at max volume only, I'm not exercised so much, because that implies use in a noisy environment, which masks this HF noise for me.
*I keep making the point about hearing limitations because I have 16 LED lights which are otherwise wonderful, but when their internal fan kicks into medium speed, they put out a mechanical 8kHz tone that drove us crazy. The fascinating thing was that we had to do 4 shows with some major acts before we could fix it, and not one musician complained about it or even noticed it. When we showed the problem to the promoters of the events, they couldn't hear it, either, even with an otherwise dead-silent stage. I would classify those people as music connoisseurs and very, very knowledgeable, but they have a hearing limitation that obviously does not affect their enjoyment of music or their interpersonal verbal communications.
People are different; after the above experience, I don't expect other people to hear what I can hear, and I know my hearing above 10kHz or so drops off significantly compared with what younger people can hear. Shrug.
And to conclude what I hope is NOT coming across as a rant, I'll remind the world that in an earlier reply in this thread about this issue, I half-seriously offered to come to Behringer Service to help them figure out why they are not observing this noise as a problem. That offer still stands, especially in light of your experience. I've never been to Las Vegas...
Call For Help - Scene Files
Folks,
Im currently testing the next phase of my Scene Management application and it can now upload scenes directly from the app to the X32 :D~:-D~:grin:
Before I release it for public testing I want to test it properly and this is where Im asking for as much help from you folks can give me.
I looking for as many different scene files as I can get my hands on (the more complicated the better).
I will upload these files using my application to the X32 then resave them using XControl and compare the upload file against the saved file to make sure they are the same.
If anyone is willing to donate a scene file for test then please PM me and I will send you an email address that they can be sent to.
Thanks in advance to anyone who helps :D~:-D~:grin:
Kev
Well, the main problem for me is that, by using two analog outs for monitor out, I'm short of those two outs which I need for the wedges...so instead of having a 16 out desk, I end up with 14 outs. Unfortunately, not an ideal sollution.
Assuming that I do not care about voiding the warranty, is there a fix? Sending the console to a Behringer service center is not an option, since it is too costly from my location, and the customs procedure is too complicated.
Any of the Behringer representatives care to elaborate?
Agreed that it's not ideal.
Are you really using it as a 16 mix monitor console? L-R-Sub + 13 mixes? Multiple delays? 32 inputs are enough for such a thing? I'd like to hear how you are using it, if you wouldn't mind describing. Same artist all the time? One nighters? Or what? Thanks!
Just to confirm -
I have now had three consoles and all of them had the problem to some degree - The first one was really bad, the second one just as bad, and the one I have now still bothers me but not as bad as the first two.
The guys at Behringer (Melbourne Australia) were really good and tried so hard. The problem however still exists but to a lesser extent than the first two x32s. If someone figures out a solution, please let me know as I'd love to get rid of it once and for all.
Mine is installed in a quiet studio, and I walked pass the big monitors today - they have slot tweeters and they nearly ripped my head off!
Thanks
Pauly
An odd one - has anyone experienced random short bursts of digital noise coming through the outputs? I've heard it happen on mine a few times in the last couple weeks, but it's so intermittent and random, that havent been able to reproduce it to tell if it's the desk itself, or if it's something on one of the inputs... only inputs (via S16) are 3x wired mics, acoustic+bass guitars direct in, some vDrums direct in, and a Sennheiser lapel (which was off+muted when it happened).
I don't think that anybody's denying that there is minor low-level noise on the headphone amp on some consoles.
You stated that needed 16 outputs so that you could run the foldbacks that you needed:
Someone tried to help you out by suggesting a very good workaround of using the aux outs. It may be helpful to consider that for the most part that people who respond on the boards are audio enthusiasts who participating in the community, are not being paid for this, and are trying to help. (A few, like me, are just posers.)
Yes, but why not have a fully functional product which you paid for?
So I would argue that even with the not-dead-quiet headphone amp that the console is still fully functional. Perfection doesn't exist in this world. The console still does the job that it was specified to do.
Its also troubling to me that you don't want to explore the return to behringer for repair option. If you want a 100% issue free desk - they have been more than clear on how to go about returning it. I have not explored the issue as to who ponies up for shipping, maybe someone could chime in here. You might want to exhaust all your recourse options before belly aching that you have decreased functionality.
Hi Michael,
Going to PM you now concerning the above.
Kind Regards,
Fiona Hammond
CARE EMEA
MUSIC Group
BEHRINGER
I dunno man. The fact that you can hear noise on the outputs tells me that it's working; fully and functionally. :roll:
Aaron, that reminds me of a "briefcase" gig I did in the last century. Up and down national artist playing a home-town gig. His manager hires production and "4-walls" a nightclub, then calls me to mix the show. I arrive at the club and find the PA stacked & wired, wedges kind of in position, mostly patched. I patch my portable CD player (remember those?) and power up the rig. It hums. Loudly. I call the hire company and the owner tells me, "it hums so you'll know the amps are on. (big pause) Just kick the amp rack on the left side, it will stop." I kicked the rack and it hummed louder. Another kick and it was quiet the rest of the night.
It should have come with a sign:
"Would you like the speakers to hum louder? Kick once for yes, twice for no."
I had something similar happen during my festival two weeks ago, which I'm still warming up to write fully about.
It occurred when I was adjusting the snake position on the main stage. The snake was a couple of the Belden Dura Tough (Data Tough?) cables that someone here suggested
TecNec Neutrik Ethercon / Belden Data Tuff CAT5e Cable Assemblies by TecNec CAT-5 Cables at Markertek.com
along with power cable and some analog 4 pair.
The mess* was running under some tables that had legs that looked like ] laying on its side, making a low space below the crossbar. The cable mess was kind of coiled but not kinked, and I pulled on it to pull it through the space under the leg assembly to straighten it out.
The PA which was on, emitted a burst of pink noise sounding stuff, and stopped when I stopped pulling. I pulled again, and it did it again.
My FOH engineer, who is one of the most experienced PA techs in the NW if not the world, and I looked at each other, and he was as baffled as I. He said maybe the dynamic kinking of the cable was enough to interrupt the sync? But neither of us had a better explanation, and the cable had tested out OK earlier with a Greenlee tester. I bought this cable because it purports to be one of the toughest CAT 5 cables available.
The cable assembly/mess was where it needed to be by that time, and we left it alone, and it performed perfectly for the rest of the 5 days with no more bursts of anything.
Was anything similar happening when your burst occurred? Maybe there is something in your cable which is accomplishing the same thing?
And was your wireless receiver input muted on your console for sure when your noise happened, and not just the transmitter turned off?
Good luck.
*Not really a mess.
