Re: Webinars on youtube
I guess exporting the show and posting it here could be a start, maybe someone can spot something unusual. I'm asking for a show export because the scene might not tell everything (it is possible that when you imported to the X32 that works, that some setting that might be the culprit didn't get transferred because of global settings, but that is a long shot).
For possible causes of the whine, the effects section is the most obvious, but with all that routing going on with the S16s, one could inadvertingly cause a loop somewhere, and sometimes this might not be obvious unless you also take the S16 modi into account, so it would be helpful to know what modus they are set to. The latter is an absolute long shot and I can't even explain how it happens, but I got something like that when the S16 was connected and not set to the correct mode (I think, didn't really figure it out because I never figured out what was the cause and what was the actual setting at the time)
With the X32 and the two S16 in different locations, maybe being powered from different circuits etc., there is a possibility of some ground loop induced interference, static discharge etc. that might cause something, who knows?
Please Guys can you help me? Any ideas.
My brain has reached it´s limits I think
Regards Gunnar Åkerlund
