Re: Pop. crackle and feedback problems
It will stay digital with no conversion and no latency.
My understanding was that was the case if you used external connections (ie via analog i/o). Even if you dont physically connect the points, is the signal tap in the analog realm?
To clarify my question..if I select Bus 15 as the source for Aux 1 input, is that tap pre or post D/A?
