Re: Digital Split/monitor desk
Thank you. This is exactly the step I was missing. It's not documented in the manual that I found, but it makes total sense. The sample rate needs to be the same for both boards as well. Strangely, the two brand new boards I was setting up were set to different rates out of the box. Matched them up, and everything is now wonderful.
My plan will be to plug everything into the monitor console, and FOH outputs will be patched back to the monitor board as well. That way, if crap hits the fan and one board goes down, or the cat 5 cable gets chewed by a squirrel, or one of the board operators dies, it's a simple routing change and we're back online. The only downside is that the pre-amp control is set on the monitor board only. At least you can tweak the trim up or down from the FOH board, so as long as it's close and not into clip on the monitor console, it'll work great.
I'm not sure why, but I seem to have found that you need to set the SYNCHRONIZATION to AES50-A/B on the FOH board as well. Do this in SETUP UTILITY Config tab I believe- I'm not at the console just now.
