Re: Master/Slave X32 with X32 Compact
Yes, treat all inputs the same, that makes it easier to mix.Hi all. I have some questions about metering: Basically I understand that with the 32 main analog channels I should set my Gain to about -18dB. So:
1. How about for Aux input? Is it the same?.
As Tim said, it depends what level you need downstream, but -18 is a good place to start.2. How does it work for Analog outputs? Like if I have a mix bus being used for a monitor send, what should those meters read for that bus?.
It is still the same. If you have ten sources at -18dB and you put their faders up to the 0dB marking and you have 0dB on the subgroup/mixbus then those ten sources will combine to give you -8dB at the output, so normally you would not pull the faders quite up to 0dB except for the solo voice/instrument. Again, your exact target level depends on the downstream equipment, but you should try to avoid using up all the headroom on the outputs.3. How about the LR meters that are on the right hand side of the display? It seems like keeping those at -18dB is going to be difficult. Am I supposed to or is that meter different.
