Re: scene help please
So why don't we start with some common mistakes, like routing the effects returns back to the effect sends. If you look at the sends, you'll see that most effect returns are sending back to the effect send buses 13-16, turning all these down, will clear up a lot of garbage.
Your effect send buses are routed to mains, they shouldn't be. Turn off the LR assignment for these buses, these should only be on for subgroups going to the main mix and off for effect- and monitor sends.
You are sending straight from vocal group to matrix 3&4, is this intentional? You are also sending to these matrices from both LR and CM. As it is, aside from potential confusion of having so many routings of a signal to the same destination, in this case, what goes through both LR and straight to matrices will be subject to phase issues because of the GEQ insert on LR.
What channels are coming through garbled?
There are also some issues where your sends for 5 to 10 is sub group, while the assignments on those buses suggest they are not sub groups, but individual buses that should have individual sends. Channel 9 f.e. is sending to monitor 5 and vocal group plus effects.
Any help appreciated. Seem to be getting some sort of processing on spoken vocals going to center bus. E6's w. new slx shure just coming out garbled. Any other fixes or suggestions appreciated, my first digital board set up.
