Re: X32 Rack Review
Got it Dan! Thanks.
The next step today was MIDI scene recall.
I got out my trusty Behringer FCB1010 that I purchased years and years ago to do some fancy MIDI control of the band that I later found I didn't need, and didn't have time in a gig to do anyway. I should note that this particular piece of gear has withstood my wife's dislike of gear I have, but don't use (which I point out is much less now than it was 10 years ago
). I had been doing strange things with the FCB and had to reset the beast to factory default so I could set it up for its new role.
I had to track down a MIDI cable, plug the FCB MIDI out into the X32 Rack MIDI in and I felt I should be in business!
I had previously setup scenes on X32 Edit having the following properties:
Again, you can't use either the iPad app OR the X32 edit program to do this. It ONLY works on the console.
So I punch the FCB on channel 2 and 1 back and fourth and ...... nothing happens. Hmmm.
I go to the Setup-Remote menu and check MIDI in/out under "MIDI in/out". This change doesn't register in either my iPad or X32 Edit .... but ....
I punched the FCB again .... woot!!! It worked.
The iPad app correctly tracks the scene changes (if you are on the "Scenes" tab), but again the X32 Edit program doesn't show the right scene at the top of the page or on the Scene tab. It does reflect the correct mixer settings though, so it isn't the end of the world.
I would note here that the scene changes are INSTANTANEOUS and all settings for the mixer are reflected on the iPad and PC just as fast. This feature is so good that I think you could even use it to boost different singers in a song if you wanted to (or different instruments). Well done to Behringer.
Hi Scott,
Thanks for sharing this interesting story.
Regarding scenes, can you save them as a show on the PC to a USB stick and transfer that way?
FWIW, I haven't had luck on the full console exporting and importing scenes; shows, yes, but not individual scenes. I presume I'm doing something wrong, but it hasn't been necessary to me to spend time figuring it out.
Good luck,
Dan
Got it Dan! Thanks.
- Under Setup-Global, the "Confirm Popups" for scene load was unchecked
- Under Setup-Remote, the "MIDI IN/OUT" Enable MIDI Scene recall was checked
