Re: X32 Discussion
The links for the download refer me to an outlook login session. Is it working for anyone else?
just copy the text, it is only the link behind it that has the wrong destination.
~~:smile: :razz:and we are perfectly decided ensuring the X32 will not suffer from over-engineered featuritis, one day..
:thumbup: The light feels a lot better, a definitive improvement as it is (much) easier to read if the tap was in perfect time.Hence, we applied 2 improvements to the function. First we introduced a sanity-check for measured tap times. Everything inside a +/-10% window will be counted into the running average. Moderate tempo changes will moderately be followed. Anything outside that window will start a new sequence, allowing to follow dramatic tempo changes quasi-immediately. The other improvement has to do with synchronizing the flashing LED with the tap moment, which intutively reassures the user that his "tap command" was "understood" correctly. So, the flashing light is on the down-beat now.
Just updated X 32 Rack....iPad app....Auxes,FX, Busses, Mtx-Main....faders are all grayed out and not functioning.
.....Are you connected? You probably need to set the ip-address again
X32 Firmware 2.05: www.behringerdownload.de/X32/X32_Firmware_2.05.zip
Unfortunately, the answer to that question is "In my head", so you just have to keep bothering me :razz:
I think this is about all there is: http://x32wiki.music-group.com/index.php?title=V2.0_Firmware:_Scene/Snippet/Cue_Management
This link doesn't work for rme - the others do.
I apologize, John and Per and others,
my mistake posting the wrong url and not testing the ftp uploads before.
Please find the corrected download links below, and ONLY use these files, which will officially be linked from behringer.com as soon as the content server allows. That should solve your iPad issue, John. Sorry for any inconvenience.
To Per,
please note that the tap function actually responds to button-down, rather than release, for measuring the time. So, it is consistent with the flashing LED. I intensively tried small and radical tempo changes, and the new tap-routine with plausibility check seems to follow easily whatever I do. Let me know it feels more intuitive and reassuring for you as well. Happy tapping, everybody ~:-D~:grin:
Release notes 2.05 PDF: http://www.behringerdownload.de/X32/X32_Firmware_Update_V2.05_2014-05-27_Rev.1.pdf
X32-Edit PC: www.behringerdownload.de/X32/X32-Edit_V2.1_PC.zip
X32-Edit MAC: www.behringerdownload.de/X32/X32-Edit_V2.1_MAC.zip
X32-Edit Linux: www.behringerdownload.de/X32/X32-Edit_V2.1_LINUX.tar.gz
